Moderate Engine Knock Detected- Cobb AP
Results 1 to 11 of 11
This is a discussion on Moderate Engine Knock Detected- Cobb AP within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I am going to moving up to stage 2 here soon and wanted to get to know my machine a ...
    Oct 2012
    Central, Pa
    I am going to moving up to stage 2 here soon and wanted to get to know my machine a little bit better before i just start throwing mods on. I've read a good article on how to look at this stuff but its just not really clicking yet, so i did about a 40 min data log. It starts cruising at highway speed then towards the end it is all country roads. Earlier today when i noticed knock i retarded the timing 1 degree but obviously didn't help. The only mods i have done to my car are Cobb AP Stage 1 93 (-1 Degree), Spt cat back and Spt boost gauge. Datalog1-2.txt
    EDIT: I don't know how to neaten this up but at Time:659.07 -1.4 is the feedback knock
    Oct 2005
    Late Devonian
    That is pretty weird. Yeah though, pulling 1 degree isn't going to do anything about that.
    It is a low RPM low throttle log and without even changing throttle position, speed, or load it all of a sudden pulls timing and keeps on pulling it until -11 and there is no learned knock in that area. I wish I could see what an accurate A/F sensor would have shown. BTW, -11 is massive, not moderate. If I am reading it right I'd be concerned enough not to drive it into boost.
    I think for it to pull that much timing and not correct itself it was either a packet of crappy gas (maybe some water) or myabe your knock sensor is loose and rattling around at that RPM? Maybe there is a tear in an intake hose or a leak that opens up massively at times (seems unlikely)?
    Oct 2012
    Central, Pa
    I value and appreciate your opinion but that puts me between a rock and a hard spot considering its my DD. That is the only time I've seen it spike that high so far. I will try to post the other part of the log that gradually hits -1.4 then gradually declines. Also I've done several WOT on the same log from ~2500 rpm up to 5700 rpm and each time no knock whatsoever showed up. Seemed to happen all between the 2500 and 3000 rpm cruising. I will put another section of the log into the next post.
    Oct 2012
    Central, Pa
    Is the knock sensor accessible from the outside of the engine? And what do you think about turning back to the stage 1 lower octane fuel tune to help it until i can figure this problem out?
    Here are the parts of the log of what the "normal" knock looks like and a boosted pull with no knock.Datalog2.txt
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I have a hard time seeing the text files line up with the columns, but am I seeing it correct that the column that builds from -1.4 to -11.8 is feedback knock? If so, that is a serious issue. Are you running 93 octane fuel in your car?
    Probably not the cause of knock up to levels of 11.8, but out of curiousity...Do you drive around with your defrost on all the time?
    Oct 2005
    Late Devonian
    If you don't see it again, it was the gas IMO.
    Oct 2013
    Is there an issue with constantly having the defroster on? Here in New England I find myself doing this fairly consistently.
    Oct 2005
    Late Devonian
    Quote Originally Posted by Ryno10rex View Post
    Stage one map is NOT recommended for a stage II car.
    Yes, the knock sensor is outside the motor.
    Knock Sensor Location - Subaru Impreza WRX STI Forums: IWSTI.com
    It has to be torqued to the right spec. and it has to be in the correct orientation (clocking). I did one on an outback without removing the manifold - you need to take off the TMIC and it will still be hard to get to (they mention a crows-foot). If you replace it, use ONLY OEM (or the exact same part from the manufacturer). I found a real OEM one for cheap on ebay or the outback.
    Oct 2012
    Central, Pa
    Yes I run 93 and i'm as particular as I can be when it comes time to fill up the tank. I hardly use the defroster maybe on a cold morning, for random knowledge though what affect does that have?
    I am still stage 1, but not for to much longer! I will go with the bad gas theory and keep a close eye on it.
    Nov 2012
    I've noticed that if I drive around with the A/C or defroster on then I will get random knock events (mostly low boost, not full throttle, as the defroster is disabled at WOT). Not large amounts of knock (below -4 ish), but without them on I never get knock.
    Oct 2012
    Central, Pa
    Good to know and troubleshoot if i see this problem in the future. Thanks guys
