2014 WRX Datalogs - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on 2014 WRX Datalogs within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; If I was it was slight. It was a stretch of highway that seemed pretty flat and straight. I really ...
    Registered User Nayrb37's Avatar
    Sep 2013
    New Jersey
    I really appreciate the input. My last fun car was a V8, so tuners and turbos are completely new to me.
    Sent from my iPhone
    2014 Subaru WRX WRB Stage 1
    Stink-Eye Mob # 1.618
    Previous Vehicles: 2010 Subaru Impreza 2.5i; 1997 Ford Mustang Cobra; 1998 Audi A4 1.8T; 1995 Ford Mustang
    “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
    Quote Originally Posted by Nayrb37
    I'll give you a quick boost control 101...
    There are three basic tables in terms of boost control:
    1) Target Boost
    2) Wastegate Duty Cycle
    3) Turbo Dynamics
    Boost targets are achieved using the wastegate to either remain closed to let air spin the turbine wheel or divert it to limit it. You typically have a min/max wastegate duty cycle, which is adjusted based on the turbo dynamics tables which measure boost error. So, if you overshoot your intended boost target, you will go "back to normal" by reducing WGDC (and diverting more air from hitting the turbine wheel) based on the TD tables. If it isn't a replicable event (e.g., you overshoot consistently, which means you need to reduce your min/max values), then just let the TD tables do their job.
    Resident Tuner @ WTF Tuning
    Sep 2013
    New Jersey
    Thanks for the explanation. Turbo dynamics tables are a completely new concept to me. Other than that, I have a basic knowledge of turbo systems. I have definitely added to that knowledge from just reading this forum. I always enjoy learning new things.
    I have noticed a difference in the way my car pulls with the Stage 1. Not a lot faster overall, but the car seems to be more responsive and pulls more through the entire RPM range. Before I would hit the gas and it would go, then I would feel a delayed "woosh" of rapid acceleration.
  6. #19
    Sep 2013
    New Jersey
    3 more recent datalogs from my drive to work.
    One is getting to the highway. Two is on the highway and a short WOT. Three is on the highway at cruising speed (no cruise control). The first log showed a bit of knock feedback towards the end.
    11/20/13 DL1
    11/20/13 DL2
    11/20/13 DL3
  7. #20
    Much of those logs are useless. You want WOT logs from 2K-redline.
    The feedback knock you have appears to be during a shift. If you can't repeat it (load/RPM), you can ignore it anyway.
  8. #21
    Oct 2013
    i also have a 2014 with the same map im trying to figure out how can i upload the file on here to take a look also what parameters should i pick to data-log to get good readings? thanks
  9. #22
    Oct 2013
    The access tuner race is available now for the 2014
