03 Bugeye Stage 2 Datalogg
Results 1 to 8 of 8
This is a discussion on 03 Bugeye Stage 2 Datalogg within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Installed a Catless 3"DP + Ran stage 2 MAP from cobb at first and car was running fine for a ...
    Oct 2013
    San Diego
    Installed a Catless 3"DP + Ran stage 2 MAP from cobb at first and car was running fine for a while. boosting max at 14psi & suddenly it started only hitting aroun 11psi max. So i decided to run stage 2 HWG map from cobb.
    Datalogged with a stage 2 91otcn HWG Map from cobb. just wanted to share & see if i could get some answers since im fairly new to tuning and datalogging.
    https://drive.google.com/file/d/0B2_...it?usp=sharing
    THANKS!
    Palmyra, NJ
    Gotta make your document public. It's saying I need permission to view.
    Oct 2013
    San Diego
    Sorry about that bud but here ya go
    Oct 2013
    San Diego
    Oh and P0031 is on just to add that to the factors
            MainFrame's Avatar
    Austin, TX
    Well.. it's an incomplete pull, and not wide open throttle. And for some reason your DAM is down at the start. Did you just flash the map?
    Oct 2013
    San Diego
    Yeah I just got done flashing the map a few minutes before I logged. What's the proper number the DAM should be at?
    Registered User teddy37's Avatar
    May 2010
    Garrett County Maryland
    +1
    2011 Wrx DGM TP Stage 3
    Stink-eye mob #3737
            MainFrame's Avatar
    Austin, TX
    16.. depending on the map, it will start off lower and add in more timing incrementally until it gets up to 16 (or 1.0 for newer models).
