injectors.. suggestions?
Results 1 to 4 of 4
This is a discussion on injectors.. suggestions? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I'm looking at swapping a 16G in for my 2.0l's TD04 sometime in the future. I'm looking at getting some ...
    Registered User pete25r's Avatar
    Jan 2011
    Maryland
    I'm looking at getting some 725/750cc.
    I don't want to go overboard but I don't want to run out of headroom.
    Also I'm DIY tuning so I want an injector set that is easy-ish to tune.
    Budget, I need it on the low but not ebay-low, gotta save for up for a turbo and intercooler.
    Also my car is a DD, no track use. Just fun on the highway at or slightly below the limit.
    So I'm looking for injector suggestions as is make/size.
    N.E.R.D. # 3.579545 MHz
    Bugeye Mafia v 2.0 # 371
    pete25r's build
            MainFrame's Avatar
    Austin, TX
    I would pick up some Injector Dynamics 725cc injectors.. or if you think you might go bigger in the future (or run e85), go ahead and get ID1000s.
    Moderator Donkey's Avatar
    Da boonies,Va
    650cc would be plenty on pump gas. Depending on what size 16g even pinks or factory dark blues (565cc) would work.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2011
    Maryland
    Thanks for the input gentlemen.
    I was looking for some pros/cons to the different brands, moreso as in which ones are a PITA to tune. I dug around here and the nasty-sock and didn't find any real opinions, well not any that didn't pass the BS factor.
    Planned setup
    16G - probably Blouch
    650-725cc injectors
    pump gas
    DD that puts a smile on my face, passengers too...
    I want plug and play injectors as far as pig tails or whatever. Yes I know they'll need to be scaled/tuned after I get my MAF scaling really tight. Just trying to plan out the hardware.
    pete25r's build
