p0301 and p0303 misfire codes 2011 wrx
Results 1 to 4 of 4
This is a discussion on p0301 and p0303 misfire codes 2011 wrx within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hello fellas, Nick here, have a 2011 wrx wagon. Absolutely love the car. I have been seeing some issues lately ...
    Nov 2013
    Hello fellas,
    Nick here, have a 2011 wrx wagon. Absolutely love the car. I have been seeing some issues lately (no mods this my daily driver, keep the 68 mustang for all that fun stuff). Ive been working on cars for a while, but mostly rest-mods and such, first venture into the world not turbo 4s, not more tunning carbs through sound car makes anymore i guess.
    I truthfully bought this car to avoid spending my weekends working on it. But I have seen the same 2 codes come up and the dealer has basically telling me its 1500 bucks to guess what the problem is without exactly being sure what caused the issue.
    Codes
    P0301 and P0303 cylinder missfire.
    Dealer did roughness test, slight roughness in both cylinders (~1-2%). cleared codes and set if it comes back then they will have to take the motor apart for 1500 with hopes that all it needs is a valve job
    Car has 54K on it, going to change plugs, etc as per the 60K major service. Any other suggestions?
    Thanks in advance.
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    actually as a fellow tuner (edelbrock personally) on a old v8 guy who's had a wrx for a bit, you start to learn the sound of it not running right fairly quick. which is good, lol. i came from a 84 camaro ive owned since 94 and its been my only car, race car(scca and drag)hotrod and car show ride when the paint was still fresh. all that wrench time of yours will pay off with diy labor. i do hope that your car doesnt have bad/cracked valves though. great time for head gaskets(they apparently leak more than my old 350's valve cover gaskets) that said they should be able to diag with the standard battery of compression and vacuum tests for bad valves. i hope.
    as far as the plugs go though. follow the advice from the club members. the irridium plugs i bought came factory set at .044, supposedly for my car year make model(02 wrx) no. so wrong. poor running, rough starting and studdering under mild throttle and partial boost. read threads on plugs and found i had 'turbo blow out' the boost was killing the plugs spark partially. so regap to .033 i think and all's better. more boost means smaller gap, totally backwards from my old v8 and big a%% MSD ignition with a huge gap of like .070 i think. its a big curve lol but its fun once you get going!
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by ndrake86 View Post
    Hello fellas,
    Codes
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
    Quote Originally Posted by tirerob View Post
    as far as the plugs go though. follow the advice from the club members. the irridium plugs i bought came factory set at .044 !
    Sounds like they gave you plugs for a N/A 2.5L I would double check the part numbers.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2013
    Thanks for the Guide link. That is actually what brought me to the forum and what I have been working off of.
    So far I have replaced the plugs, gapped to .028. I pulled number one plug and it was gapped closer to .016. Not a whole lot of carbon build up. I am pulling out the MAF today and will clean out with the MAF cleaner.
    I have checked almost everything else on that list. Except for the valve clearance (which i just dont have the tools to do here in my tiny apartment).
    The one BIG question I have is, I was able to score some Mopar Combustion Chamber Cleaner (MCCC). It says spray directly into the Throttle body. I know that this would be simple on a non-turbo mopar/ford/chevy, but who would I go about this for the WRX?
    Do I need to remove the intercooler to spray in and will the car be ok without the intercooler on. I have read that for seafoam you put in through a BPV (might have that wrong) but this is a spray can and not something I could poor. Any suggestions would be awesome.
    Thanks for all the help. Any yes I truely miss the old carb days. Missing tuning the speed demon on mustang now for sure.
