Vibration and deep sound at WOT low RPM TP stage 1 map
Page 1 of 4 1234 LastLast
Results 1 to 15 of 60
This is a discussion on Vibration and deep sound at WOT low RPM TP stage 1 map within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hi, I run the torqued performance stage 1 map on my WRX 2011 for a month. This just amazing. However, ...
    Sep 2013
    Hi,
    I run the torqued performance stage 1 map on my WRX 2011 for a month. This just amazing. However, At low RPM (2000) at wot when I build boost until 3700 rpm there is a strong vibration with a big noise. No exhaust leak, and the bolts of the downpipe are good.
    any idea?
    thank you
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Sounds likes something your girlfriend would enjoy.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Sep 2013
    Actually yes.
    zax
    zax is offline
    Nov 2008
    Then I vote keep it!
    Facebook me here
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    What gear are you pulling in? It sounds to me like you're lugging down the engine until you hit boost and the torque curve catches up.
    Also: to Zach.
    2007 Outback 3.0R wagon
    Sep 2013
    I happen just in 4t and 5th gear. When going wot at low rpm.
    Yes Zach is the man
    Oct 2010
    Portland, OR
    Quote Originally Posted by rickson View Post
    Well there you go. I never shifted into 4th below 50-ish mph and at least 3.5k rpms.
    Sep 2013
    Why not?
    Oct 2010
    Portland, OR
    Why not?
    Because I prefer my car to move. You're not even hitting boost below that point, so why shift?
    Sep 2013
    This is just a way to drive. I read that going WOT at low RPM in 4th or 5th could be bad for cars. True?
    Oct 2010
    Portland, OR
    It could be. Lugging can cause sporatic knock issues, and puts undo stress on the connecting rods. Why are you shifting so early? I doubt you'll see much in the way of fuel savings, if that's your goal.
    Jul 2012
    Rocky Top
    Quote Originally Posted by Rambo View Post
    I usually start my car out in like 3rd or 4th. Why shift at all? Rambo is just a Moody Judy. You'll be fine.
    Registered User SDub's Avatar
    Feb 2013
    You shouldn't be WOT at low rpm in high gears. Not good for the motor. The low rumble and the vibration is shock on your drive train and stress to your engine.
    It's like starting out in 3rd, yeah you can feather you clutch and move your car, doesn't mean you should.
    Just double clutch and Down shift. Get to a higher Rpm then upshift.
    Just my experience and opinion.
    Sent from my Fone
    Oct 2010
    Portland, OR
    Quote Originally Posted by wreckingball man View Post
    Sep 2013
    Actually at 60mph I am around 2500rmp. in 5th so .... At wot (for any reason...) I go from 2500 to 3500 where I hit 18psi and herd and feel the vibration.
