Stage 1 log
Results 1 to 6 of 6
This is a discussion on Stage 1 log within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So I just flashed my car with a Torqued performance stage one tune, easier than I thought it would be. ...
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    Stage 1 log
    So I just flashed my car with a Torqued performance stage one tune, easier than I thought it would be. I was only able to do one pull because of traffic, and did not want to risk my life or anyone else's life for that matter. From my very limited knowledge I think the pull looks good, but would like to get some opinions from the better informed. And yes, I have sent the log to TP, just figured that I would not get a response with it being so late. Thank you so much for looking.
    https://docs.google.com/spreadsheet/...rive_web#gid=0
    Stock pullhttps://docs.google.com/spreadsheet/...rive_web#gid=0
    Also, I have a virtual dyno comparing stock to the stage 1 logs, I am having a hard time grasping the difference. They were done two days apart at the same location, 1st being stock at 7:30pm @ 66 degrees 80% humidity, 2nd being stage 6:30pm 1 @ 60 degrees 73%. I know it is virtual, but I highly doubt a stage 1 makes that big of a change.
    '11 WRX DGM
    Aug 2012
    Spring Grove, PA
    Sorry! I am an idiot, I forgot to take it off of private... I do this every time
    Should work now
    '11 WRX DGM
    Do you have a stock datalog you can share?
    You're pushing significantly more air into the cylinders on the S1 tune vs stock. The only useful before/after information we have now is manifold pressure, which doesn't factor in ignition advance, cam advance, or AFR differences (which all play a part in making more power).
    Resident Tuner @ WTF Tuning
    Aug 2012
    Spring Grove, PA
    I most certainly do, I have added it to the original post... Sadly though I forgot to log ITT, and certain logging parameters are not the same or are not there during the stock pull, so I do not know if it will be of any use :/
    '11 WRX DGM
    Quote Originally Posted by Kwrxp
    Nope. Boost numbers alone don't tell the full story. Unfortunately, you'll either need to go back to stock and get the proper parameters or not worry about it.
    Aug 2012
    Spring Grove, PA
    That is what I thought, and thanks for the help you have given me as I do appreciate it. Eric has taken a look at it and told me that that was what he was looking for, and that it looked good to him. I probably will take it back to stock and do a few "correct" pulls to get a real comparison. Again thank you.
    '11 WRX DGM
