Fuel cut during WOT using MBC
Results 1 to 13 of 13
This is a discussion on Fuel cut during WOT using MBC within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So recently my stock bcs stopped working and I replaced it with a hallman type mbc. I have a tuner ...
    Registered User Random2006's Avatar
    Feb 2012
    Springfield, MO
    So recently my stock bcs stopped working and I replaced it with a hallman type mbc. I have a tuner that's been etunning my car and has been great to work with me. So I installed the mbc and slowly started to adjust the boost level to creep up to the target level which was around 17psi. After passing 13-14 psi I start to get fuel cut and the car lunges. The only time I've ever had the same issue is when I was overboosting due to a vac leak some time ago. Tried a new tune setup and still having issues. Wondering if I should continue working with the tuner or if I should be looking at hardware that could be the cause. I've read that the stock bpv sometimes has this issue but I switched mine out with a friends STi a while back when he was trading up so that shouldn't be the issue. No apparent air leaks and the only mod is k&n typhoon intake. Just hoping for some feedback before I continue to bug my tuner.
    Stephen
    http://forums.nasioc.com/forums/showthread.php?t=533787 <--- Good Info
    2002 Impreza WRX "BugEye"
    What does your tuner say?
    Resident Tuner @ WTF Tuning
    Feb 2012
    Springfield, MO
    He hasn't replied yet, I was just wondering if I should be looking for something on my end.
    Stephen
            MainFrame's Avatar
    Austin, TX
    It's hard to say with no data to go on. Some logs, or even a copy of your map should shed some light on what's happening.
    Feb 2012
    Springfield, MO
    Computer wouldn't allow me to upload cvs files so I'll have to convert the file before I can share it. My tuner says it may be the fuel pump
    Stephen
            MainFrame's Avatar
    Austin, TX
    Do you have a wideband O2 sensor installed?
    Feb 2012
    Springfield, MO
    Just going off of romraider logger. Haven't had the money to spend on gauges.
    Stephen
    Feb 2012
    Springfield, MO
    So I'm going to replace the fuel filter and possibly the lines that connect to it. I'm getting a strong gas smell around that area. There is also another filter like device that is on the line next to the fuel filter. Anyone know what this is?
    Stephen
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Random2006 View Post
    Pressure regulator?
    Feb 2012
    Springfield, MO
    I took it off to see if it had blockage and it was hollow. Some kind of dampener I suppose. There also wasn't any pressure I that line.
    Stephen
    Did your tuner ever get back to you?
    Feb 2012
    Springfield, MO
    Yes he said my issue is fuel related.
    Stephen
    Feb 2012
    Springfield, MO
    The issue ended up being the Bosch spark plugs I had. Replaced with NGK and bam full boost.
    Sent from my SCH-I535 using Tapatalk
    Stephen
