Possible stage 1 knock??? - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
This is a discussion on Possible stage 1 knock??? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Haha. And ducati??? ppppssshhhhhh. GSX-R FTW!!!!...
  1. #31
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
  3. #32
    Registered User Kam91's Avatar
    Jul 2012
    quick question... I would like to tune the car again because I really did like the subtle increase in power stage 1 offered. My question is someone on this thread had mentioned that just because your log numbers look good doesnt mean the tune couldnt have caused the spun bearing. Is there any truth to this and is there anything I can do to better keep track of the car other then logging? I am almost positive the spun bearing was not a caused by the tune mostly because the dealer though my oil was the problem, but I am just trying to be safe. I am also wondering if its worth doing a stage 1 pro tune if thats any safer then the cobb maps or even If I should go with the torqued performance map. Any advice?
  4. #33
    Palmyra, NJ
    If a tune "caused" the spun bearing issue to occur, that means the tune was crappy and logs should have shown that. If a tune is logging well and looking good, then the issue that occurred would probably have occurred due to a mechanical issue within the engine itself (oil problem as you stated?).
    A protune more than likely would be safer as it's specific for your car. Its customized. While OTS Cobb tunes and the likes are usually fine since they are a bit more mundane and dumbed down to work with ALL cars it is designed for, it doesn't have the level of customization which provides a level of safety.
    If you want to go Stage 1, do it. If you're worried, don't do it.
  6. #34
    Sep 2013
    Montrose, CA
    I honestly dont think that your Cobb tune was the cause of a bottom end failure, lack of oil , wrong oil , or deffective oil pump or an engine put together wrong day of the week (for Ducatis it would be MOndays or Fridays!), usually failures for bad tuning are more encounter in the top end, especially derived from AF ratio being way off in between others...
    Cheers
  7. #35
    Jul 2012
    thanks I was just looking for some reassurance on the tune. My numbers were all good so I will be tuning it again Im just not sure if I want to spend the extra money to have it protuned, or what do you guys think of the torqued performance maps are they worth the 100 bucks for the map or are the cobb maps dencent enough to leave till I decide to protune it ??
  8. #36
    Sep 2013
    Montrose, CA
    sounds like a good plan! Btw I am getting my COBB AP V3 tomorrow evening , cant wait to have it up and running....
    Cheers
  9. #37
    Palmyra, NJ
    Quote Originally Posted by Kam91 View Post
    TP maps aren't terrible, but after some research and learning some things about the way those maps are built, I wouldn't do it.
    If you were to go dyno protune, I'd look into Stage 2.
    If you want to go the email tune route, look into WTF Tuning. I can vouch personally for their tuner, Matty who mods around here. I'm currently running a Stage 1 map from them and I love it. My last STI had a Stage 2 map from them and it ran incredibly well. Shoot em an email here: wtftuning@gmail.com
  10. #38
    Jul 2012
    How does the email tune work? Do they just set you up with a basic tune and you keep emailing them log numbers so they can see whats going on with the car?
  11. #39
    I wouldn't bother with slapping your car on a dyno for a S1 tune. If the tuner just wants to do a road tune, that's perfectly sufficient, and likely should save you some $ in the process.
    Any base map is going to be hit or miss. Some cars take them well, some cars won't. Some may have some minor edits that need to be made. Cobb maps, in general, aren't too bad, and shouldn't be the cause of the failure. If your car died at S1 power levels, and the car wasn't detonating like crazy, the car would've blown up stock.
    Resident Tuner @ WTF Tuning
