Please review data log - Stage-1 93 octane, Stock Intake, Stock Exhaust
Results 1 to 15 of 17
This is a discussion on Please review data log - Stage-1 93 octane, Stock Intake, Stock Exhaust within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hi All, I just install my Cobb v3 today and I did a short data logging, can you please review ...
    Registered User wrxbuzz's Avatar
    Jul 2013
    Florida
    Hi All,
    I just install my Cobb v3 today and I did a short data logging, can you please review it and let me know if anything needs to be changed?
    I'm running a 2013 WRX Sedan - Stage-I 93 octane, Stock Intake, Stock Exhaust.
    Current Cobb Map: Stage 1 93 MTv300
    https://dl.dropboxusercontent.com/u/...og-wrxbuzz.csv
    Thanks for the help!
    wrxbuzz
    Jan 2012
    Philly Area
    Looks ok, but that's pretty poor resolution. What gear did you do the pull in?
    - Will
    Jul 2013
    Florida
    I was on 3rd Gear. What do you mean by poor resolution?
    Jan 2012
    Philly Area
    Quote Originally Posted by wrxbuzz View Post
    Your log contains 35 rows of data. When I do a 3rd gear pull my logs contain about 200 rows of data. You can delete some of the parameters that aren't as crucial to maybe improve your resolution.
    - Will
    Jul 2013
    Florida
    Oh that's because I accidentally shut it off at my peak boost, so what you actually see is only the acceleration but not the declaration. I guess I'll have to make a new one and repost.
    Jan 2012
    Philly Area
    Werd. I still think you could get better resolution. Another way to put it: Looking at the "Time" parameter, your log reaches 1 second with 3 rows of data. Mine has 16 rows of data by the time I'm at the 1 second mark. More data is always more better with these things.
    Your log looks to be fine to me, btw, but if it were me I'd want to have more info.
    - Will
    Jul 2013
    Florida
    I see what you mean by "resolution" now, I'll try to create a new log correctly this time and submit it again. Thanks for the help!
    Jan 2012
    Philly Area
    No problem!
    - Will
    Log is clean.
    For your next log, remove the following parameters:
    1) AF Learning
    2) Dynamic Adv (°)
    3) MAF (g/sec)
    4) MAV Volt
    You can't expect anywhere near the resolution Will has by using your Cobb AP (Will is logging with an OpenPort 2.0 cable and a computer program called Romraider); it just isn't capable of it. However, removing those four parameters will help a little bit (but not much). As for the "deceleration", there's no point in logging that, as your injectors shut off and the car basically becomes a simple air pump.
    Resident Tuner @ WTF Tuning
    Jan 2012
    Philly Area
    Log is clean.
    1) AF Learning
    2) Dynamic Adv (°)
    3) MAF (g/sec)
    4) MAV Volt
    Ah...didn't catch that it was with an AP. That's why you're the tuner and I'm just some drunken fool.
    - Will
    Quote Originally Posted by Calvinball
    Easy well to tell quick in the future: DAM vs IAM (DAM = Cobb / IAM = OpenECU)
    Jan 2012
    Philly Area
    I shall not make the same mistake twice!!
    - Will
    Jul 2013
    Florida
    Just ran another log on a 4th gear on the Florida Turnpike.... please review:
    https://dl.dropboxusercontent.com/u/...g6-wrxbuzz.csv
    I am having a peak boost of 18.14 but that's on a 4th gear, should I try to run a low wastegate map or is it still within the normal margin?
    What do the Cobb map notes say?
    Jul 2013
    Florida
    RTFM I get it... ...BUT!
    "LWG: Lower wastegate duty cycles (LWG) for use when normal wastegate calibration produces higher
    than targeted boost (i.e. over boost)."
    I'm currently running this map:
    Stage1 93 MTv300
    o Fuel Requirements: 93 - 94 octane or better
    o Intake Requirements: Stock airbox with stock air filter
    o Exhaust Requirements: Stock exhaust or upgraded cat-back exhaust
    o Boost Targets: ~16.5psi peak boost pressure tapering down to ~13.5psi by the 7000RPM redline, +/- 1.0psi
    But it doesn't say how high or low type of boost, does 1-2 PSI over requires a whole new map level or is it higher than that?
    Also, I tested it on 4th gear this time. My previous test was on a 3rd gear and produced a peak boost of 16.79 which is normal.
    So I'm a bit puzzled.... Should the boost stay restricted to 16.5 at any gear whatsoever, or does the settings only apply to a 3rd gear test?
