been dealing with this for a while now *****LOGS*****
Results 1 to 12 of 12
This is a discussion on been dealing with this for a while now *****LOGS***** within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I have a 2011 wrx sedan with a ton of bolt ons. turboXS fmic/CAI, turboXS turbo back catted exhaust, perrin ...
    Registered User wrx50's Avatar
    Jun 2012
    MA
    I have a 2011 wrx sedan with a ton of bolt ons. turboXS fmic/CAI, turboXS turbo back catted exhaust, perrin inlet, grimmspeed ebcs, GReddy type S BOV recirculated, DW65C fuel pump and I believe the rest is irrelevant. Basically a decent stage 2 setup.
    I am running TP stage 3 e tune and I cant say enough about eric. However, I have had a knock or false knock issue for over a year that I can not get to the bottom of. Basically the car pulls timing and learns to pull timing at WOT under full boost. It ranges from 1* to 4+. I cant find any apparent mechanical issues and I don't hear it knocking when the issue occurs.
    I'm very sick of this car and about to trade it in if I cant fix the problem. I don't believe there is a boost leak but I could be wrong. Someone who is avid in tuning and is familiar with these cars please point me in the right direction. No CELs, not over boosting or under boosting, no smoke from tailpipes, no smoke or puffing from oil filler cap. I'm baffled at this point.
    today 3rd gear pull
    https://docs.google.com/spreadsheet/...kQmNzcFE#gid=0
    a couple days ago again 3rd gear
    https://docs.google.com/spreadsheet/...UE&usp=sharing
    this ones clean.....
    https://docs.google.com/spreadsheet/...RcVRNcnc#gid=0
    this one is not bad either....
    https://docs.google.com/spreadsheet/...0clZUUVE#gid=0
    this is the worst one yet....
    https://docs.google.com/spreadsheet/...Xc&usp=sharing
    actually this is the worst one.....
    ok......so that is just a little bit of the history of the logs......since that terrible one a revision has been made and I fear it is heading back down the same direction. Any insight would be great.
    thanks
    Greg
    Without looking at the logs, what does Eric say about it? I mean, you're paying him to tune the car (and "can't say enough about him"), so what is his input/advice?
    To check for leaks, you need to pressure/smoke test the system.
    Resident Tuner @ WTF Tuning
    Jun 2012
    MA
    Eric said the last time that the AFR learning was leaning it out. The logs are posted and public correct?
    Quote Originally Posted by wrx50
    Yeah, but I'm not sure what you want from us, bud...you're paying him to tune the car.
    In reality, he has no idea what is happening with the AFRs, because you don't have a proper way to monitor them. If he's saying that AFRs are causing the issue, get yourself a WBO2 so you can dial in fueling and fix the problem.
    Jun 2012
    MA
    I should have mentioned that. I have a wideband and it reads anywhere from 11.0-11.5 and Eric is aware of its reading. I have sent him videos during the pull. I was just hoping someone who is well versed would see the logs and recognize an issue from past experience
    Why aren't you logging the AFRs via WBO2? Again, I'm not sure what you're looking for from us. If AFRs are causing the knock, it's either a leak, your MAF scaling is off, or some compensation table is causing the problem. Remotely, he (nor anyone) can't do anything to check for a leak; that's on you. If it's not a leak, that's on the tuner.
    Jun 2012
    MA
    Okay then. Boost leak test it is
    Jun 2012
    MA
    Okay. So Ive given up on trying to fix this myself. I scheduled an apt on September 9th at the shop ct.
    Compression test first. If that comes back clear then boost leak test via pressure and smoke. Then switching the car to speed density and getting a dyno tune followed by a road tune. It may be a fuel issue so if it begins leaning out on the dyno we will fix that on the spot. Hopefully this solves the problem
    I'm pretty mechanically inclined but the issue now is solely time that I don't have to attack this myself. So it's time to hand it over to a professional......I'll keep you guys posted if anyone is interested
    slow no mo' ! Shoopster's Avatar
    Apr 2013
    Montreal
    subscribed. interested to know what the problem turns out to be. good luck!
    -Stephanie 2004 WRB WRX | Blobeye Syndicate Member #104
    "I can't see the Shoopster from here; I'll wait for you outside."
    Shoopsterbuild 2.0: Better than it was before. Better, stronger, faster. And such JDM, yo.
    Jun 2012
    MA
    Thanks. Either way a new tune is fun!!
    Glad to hear. If they're going to be doing a compression test, you may as well have them replace the plugs while they're there, so pick up a new set.
    Jun 2012
    MA
    That's not a bad idea EJ. I Will grab a new set of 1 steps
