ECU replacement?
Results 1 to 10 of 10
This is a discussion on ECU replacement? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So I'm buying a 13 wrx and I'm planning to mod it if I bought a separate ecu and changed ...
    Aug 2013
    ECU replacement?
    So I'm buying a 13 wrx and I'm planning to mod it if I bought a separate ecu and changed it before tunning could I just switch it back to the original if (knock on wood) something goes south?
    You're concerned about bricking the ECU? In addition to swapping the units you'd also have to reinstall the original parts should you chose to modify those. The replacement stock ECU will support the stock parts.
    The numbers are in your favour though. Most don't brick their ECUs. So, you are likely to flash a new map without incident. Should you in fact brick it against the odds, you could buy another ECU then.
    Registered User wrx frog's Avatar
    Jul 2013
    I would buy the ecu after its bricked, I'm not sure of the pricing for one but I'm sure its not cheap. Also I wouldnt be to concerned about messing up the ecu, I have yet to here of someone that has..
    Sent from my HTC-X710a using Tapatalk 2
    Feb 2013
    Columbia SC
    Wow I'm lost. What is "bricking"?
    2013 WRX sedan - MODS = pretty much every bolt on besides a bigger turbo.
    Registered User Upgrayedd's Avatar
    Aug 2012
    Turning it into a fancy paperweight.
    Palmyra, NJ
    Quote Originally Posted by elblanco1987 View Post
    You kill it. Something goes wrong with a flash (lose power in the middle of it, gets shorted out, etc....completely dead)...it can no longer be used. It becomes about as useful as a brick sitting somewhere.
    OP, in theory, yes you could just swap out an ECU as long as its the same make/model, but even a used one for such a new car won't be cheap. What are you worried about? Warranty issues or actually harming it?
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    You also have to be concerned with certain issues that may occur when swapping out ECU. In my previous vehicle, I had a tuned ECU. I then bought a new ECU just to have a stock back up, but with it in place of the tuned one, the cruise control not longer worked. The only way to get the new one to work correctly, was to have the dealer correct it.
    Honestly, if you are worried about them finding out you broke your car with modifications and them not fixing it under warranty, you're not going to have a whole lot of luck. A good tech can tell when a car has been taken back to stock for such reasons. So, if you want no issues with your warranty, modify it after it is up, or modify things that are less likely to cause catastrophic repair bills.
    '11 WRX DGM
    Apr 2004
    Southeastern PA
    I have one dead ECU and one unreliable ECU.
    I think my accessport just fried my ECU
    Mods & Pics
            MainFrame's Avatar
    Austin, TX
    What's your plan about the immobilizer? Sounds like a big hassle to me.
    For what it's worth, I thought the OP was talking about taking the original ECU out and using a different one to flash, in case he blows his engine to put the untampered with ECU back in the car in an attempt to defraud the dealership into performing warranty work on a car that has been modded. Not a bad idea (other than what are you going to do about the immobilizer), except for the fact that we're talking about fraud here, which is not legal.
    Quote Originally Posted by Sasquatch View Post
    I still wonder whether some sort of electrical abnormality bricked your ECU. Just seems against the odds otherwise.
