cobb ap stg 1 datalogs need help!
Results 1 to 15 of 28
This is a discussion on cobb ap stg 1 datalogs need help! within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hey all, I flashed my 13 hatch last night to stage 1 map. Car feels really good, and it did ...
    Registered User Scoob1318's Avatar
    Apr 2013
    Hey all,
    I flashed my 13 hatch last night to stage 1 map. Car feels really good, and it did help smooth out the powerband. I did 4 data logs and I am concerned about the last one I did. The first 3 were great numbers and then on the 4th log I have some fine knock learning that comes in. Any advice would be helpful as to if this is acceptable or not. Thanks for your help
    This is log 4
    https://docs.google.com/spreadsheet/...Xc&usp=sharing
    Previous logs
    https://docs.google.com/spreadsheet/...FE&usp=sharing
    https://docs.google.com/spreadsheet/...1E&usp=sharing
    https://docs.google.com/spreadsheet/...UE&usp=sharing
    Apr 2013
    Anyone? I know there are some experts out there
    Registered User wrxnguyen's Avatar
    Jul 2013
    714 Orange County
    Have you tried to log again after the 4th? I've read around saying if you can't replicate those numbers again, you shouldn't worry about it.
    Apr 2013
    I have not tried a log since, but I planned on doing a few more. I found it weird that I had 3 perfectly fine logs and then on the 4th I had knock...
    Jul 2013
    714 Orange County
    I just started reading ap numbers so I'm still learning. But try logging again is what I'd do.
    Are you on Cobb's stage 1 map? Do you have an aftermarket intake?
    Apr 2013
    No intake, only other mod is a gfb hybrid bov, set to 70 recirculating 30 bov
    Jul 2013
    714 Orange County
    Quote Originally Posted by Scoob1318 View Post
    Hmm might have something to do with that.. might be loose or not functioning properly which would cause a leak for that knock?
    Jan 2012
    Philly Area
    Do some more logs and see if it keeps happening. Did you do all 4 of those logs at the same time?
    Also, what map did you flash? None of the OTS ones are meant to work with an aftermarket BOV
    - Will
    Apr 2013
    I did the first 2 logs right after I flashed it, and then the next day I did the last two, so I have not even put 50 miles on since I flashed it. I'm going to try and set the bov to 100% recirculating but that should matter since they don't need to be tuned
    Apr 2013
    The map was the stage 1 93 normal waste gate
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
    Apr 2013
    ^ I saw a similar thread on that topic before. I a going to be running the bov to 100% recirculating so it will function the same as a stock valve.
    It isn't there on the other logs. There is talk of some false triggers of FLKC on the newer ECUs. Are you able to replicate the scenerio in Log 4?
    Resident Tuner @ WTF Tuning
    Apr 2013
    I have not tried to log since I took log #4. I will try to get a couple more in the next few days to see if it happens again. I'm assuming that's what you mean by replicate the scenario. Thanks for the responses everyone.
    Jan 2012
    Philly Area
    That's a correct assumption. You want to see if the knock continues to happen under the same circumstances. If it isn't repeatable, you don't need to worry about it.
    - Will
