unhappy with tune.. data log?
Results 1 to 15 of 26
This is a discussion on unhappy with tune.. data log? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; so as the days progress i'm becoming more and more annoyed with my tune. my car does not perform well ...
    May 2007
    orlando flawduh
    so as the days progress i'm becoming more and more annoyed with my tune. my car does not perform well in lower gears/RPMS. it seems to hesitate a little which is something it never did with my OTS stage 2 map
    would data logging diagnose any potential issues with my tune? i'm not really familiar with data logging and i've never done it before. what parameters would i set with my accessport to do the log? i know you can select different things to monitor.
    halp?
    desiree
    Oct 2005
    Late Devonian
    See 3:40 "top 5 monitors".
    You should not need to do a 4th gear pull (that was an STi) - just do 2nd gear for now as that will top out at 60mph.
    I'll look for the basic list in Cobb lingo (I can't remember what they call some stuff). It is best not to log extra stuff as it will slow down the polling so you get less lines of data and can't see what happens in between.
    It could easily be mechanical too - have you cleaned your MAF, new air filter, basic stuff?
    Oct 2005
    Late Devonian
    Here is the basic list - just need to translate it to Cobb lingo....
    feedback knock correction
    fine knock correction
    IAM
    engine speed
    engine load
    manifold relative pressure direct
    injector duty cycle
    wastegate duty cycle
    target boost
    IAT
    mass air flow
    Lc-1 (or other wideband) or AFR sensor #1 (factory front O2)
    A/F Learning #1 (%)
    Datalogging with Romraider:
    Oct 2005
    Late Devonian
    May 2007
    orlando flawduh
    thanks! pretty confident its the tune. i have done all the basics and the car is completely up to date on all maintenance.
    so just do a few pulls in 2nd gear from 2500 RPM to redline?
    i will do some pulls and post them up so you guys can take a look!
    desiree
    May 2007
    orlando flawduh
    also, i found all the parameters except IAM & IAT
    desiree
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Quote Originally Posted by wrxtreme06 View Post
    Look under the D's for dynamic advanced mult
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Moderator Donkey's Avatar
    Da boonies,Va
    Cobb calls IAM "DAM".
    2002 FORESTER S
    1998 FORESTER S
    May 2007
    orlando flawduh
    got it thanks!
    desiree
    May 2007
    orlando flawduh
    desiree
    You say the "hesitation" is in lower gears, lower RPMs. Is it at part-throttle or WOT that you feel the hesitation?
    If the hesitation isn't at WOT, a WOT log won't help us.
    That said, I'm going to ask you alter the parameters you logged, regardless, but I need to know the scenerio first...
    Resident Tuner @ WTF Tuning
    May 2007
    orlando flawduh
    The hesitation usually happens in lower gears if I get on it a little but not WOT
    desiree
    You need to capture the hesitation in datalogs. This is part-throttle issue, so that's the scenerio you should be logging, not WOT.
    1) Engine Speed
    2) Calculated Load
    3) Throttle Angle
    4) AFR Sensor 1 (AFR) - something along those lines (if you want to call me when you're looking at the parameter list, I can tell you which one)
    5) DAM
    6) Feedback Knock
    7) Fine Learned Knock
    8) Ignition Timing
    9) Boost (PSI)
    M
    May 2007
    orlando flawduh
    Ok thanks matty I'll have another look at the list and change it to those parameters
    Now can I just log a whole drive (ie: my 10 minute drive to work) or does it have to be an isolated time frame
    desiree
    Isolating logs would make it easier to identify / look at than a 10 minute drive. Otherwise, you'll have to find where in the log the hesitation occurred and tell us.
