cobb stage 1 logs
Results 1 to 5 of 5
This is a discussion on cobb stage 1 logs within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; hey everyone just pulled some logs from my 12 wrx with the cobb ots stage 1 and was wondering if ...
    Oct 2012
    grand rapids mi
    cobb stage 1 logs
    hey everyone just pulled some logs from my 12 wrx with the cobb ots stage 1 and was wondering if someone could take a look at them and let me know if everything looks good. im about to go tp stage 2 and want to make sure everything is ok before i take the plunge. thanks again.
    https://docs.google.com/file/d/0B1q-...it?usp=sharing
    Car is pulling timing across the board (DAM is .81). Something is up. Is this gas from a typical spot or new one? Do you have any heatshields rattling?
    You're below target boost. Have you verified you don't have a leak?
    Resident Tuner @ WTF Tuning
    Oct 2012
    grand rapids mi
    Gas is 93 from the local BP. I go there almost all the time. Ill check the heat shield tonight but I just replaced it with Cobb's heatshield in preperation for my downpipe install. As for the boost leak ill take a look around but I really don't know what I'm looking for.
    Quote Originally Posted by 12wrxphilly
    Check your DAM before you fill up the next time (run it as dry as you can before doing so). If you're still at least at .8, reset the ECU and keep an eye on it to see if it drops again. May just be some bad gas.
    Pressure test your intake tract or get a smoke test performed.
    Oct 2012
    grand rapids mi
    Ok ill do that this week. Thank you again. Its probably a good thing i didnt install my dp and flash to stage 2 this weekend lol.
