The "Check Out Anthony's Log" Thread and help... - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
This is a discussion on The "Check Out Anthony's Log" Thread and help... within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by xFalleNx Thanks for the reply Brandon. I'm going to scroll through this thread a bit while at ...
  1. #31
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by xFalleNx View Post
    I'm going to scroll through this thread a bit while at work today:
    RomRaider • View topic - Preemptive feedback knock correction
    I also talked to Matty last night and we're just going to start fresh on a custom tune. I feel that at this point, that is the better option.
    Not a bad course of action.
    Also, you can change the value of the "real" FBKC to a different value, which helps to point it out when you see it as well.
    You'll see that the thread was not very definitive, sadly. Still waiting for any more information to fall out of it.
    2011 STi Build Log
  3. #32
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    Just curious. Do you drive around with your A/C or defrost on all the time? I am not sure why, but when I drive around with either A/C or defrost on, I get feedback knock. When I turn it off, I don't. It can't be coincidence because I have noticed over and over again (especially at cruising speed) that if the defrost is on (or a/c), I get knock (-1.2 - 2.4 ish). The extra load the A/C or defrost is putting on the engine might be causing this...Just a thought! These other guys know a lot more about these things than I do!
    Funny story regarding this.....
    Yesterday, before I went to Zach's house I stopped at AutoZone to get some MAF cleaner and a filter kit. While on the ride, I set my AP to be reading FBKC, and I had the windows down....no knock. As soon as I was done at AutoZone, I get in my car and thing "gee it's a little hot, let me turn the AC on." Set the AP to FBKC and go about my way. I pull out of the parking lot and pull up to a light, not more that 500yds of travel, and I look down at the AP and at some point in that little blip of driving, it knocked.....So I go "okay, maybe the ac/defroster has something to do with this." So after that light I turn my a/c off and put the windows down. Didn't knock at all the rest of the way to Zach's house.
    Now overall, this is most likely just coincidence considering that my total trip from home to AZ to Zach's was about 2mi and clearly the logs that I posted last night show knock in normal driving (windows were down). I just thought that it was kinda funny that you posted that and I was thinking about it last night.
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  4. #33
    Nov 2010
    Voorhees, NJ
    I'm assuming that is something Matt will do?
    Thanks, I'll still browse through it. I'm sure that I'll learn something.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  6. #34
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    FWIW the AFR on my OTS maps were all over the place when I got a base pull before my dyno tune. When we dyno tuned my car and straightened out the AFR curve it was much much better.
    I should log my car as well. I have been running this map for 75k miles-ish. Be interesting to see whats going on.
    How long will the AP V2 log for? Will it log continuously for a 25 mile drive?
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  7. #35
    Nov 2010
    Voorhees, NJ
    I honestly don't know. I've only done small logs with the AP, more recently I've been logging via tactrix and laptop.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  8. #36
    Quote Originally Posted by 06wrx4me
    That wouldn't really be very useful. It would contain a lot of useless information that makes it difficult to parse through to get to anything useful. A bunch of shorter, more concise logs is far more helpful.
    Resident Tuner @ WTF Tuning
  9. #37
    Nov 2010
    Voorhees, NJ
    Note to self:
    Matt prefers a short log.
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  10. #38
    May 2010
    Pittsburgh, PA
    He could. I dunno.
    Use excel instead of google docs. Put on the "Freeze top row" and then use "Filter" when dealing with larger logs. It makes identifying knock events a piece of cake.
    2011 STi Build Log
  11. #39
    Nov 2010
    Voorhees, NJ
    I don't haz excel. OpenOffice spreadsheets fine?
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  12. #40
    May 2010
    Pittsburgh, PA
    I'm not sure whether they have a nice filter option or not. It allows you to basically add sorted "drop downs" for each column which you can check on/off. Very nice feature.
    2011 STi Build Log
  13. #41
    Cheeky Bastage! spirited09wrx's Avatar
    Oct 2009
    Dirty Jerz
    I will most likely always have the excel files for Anthony's log...if anyone wants the originals
    Zach
    Teh Intern @ WTF Tuning, LLC
    2009 WRB Subaru Wrx Sedan: Torqued Performance Stg2
    Stink eye Mob #287
    N.E.R.D. #43252003274489856000 (the total number of configurations of the Rubik cube)
    "It's not turbo-lag, it's foreplay"
