2013 stage 2 wrx datalog please help
Results 1 to 7 of 7
This is a discussion on 2013 stage 2 wrx datalog please help within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; im having some issues with my car...ive went stage 2 and since ive done this upgrade ive had nothing but ...
    Apr 2013
    im having some issues with my car...ive went stage 2 and since ive done this upgrade ive had nothing but issues im currently at 1700 miles...from what it seems like 2 me ive had some boost leak issues but i have no way 2 confirm that also...i had oil in my intercooler and white smoke shoots out of car at every start up....i have people who have the same exact setup as i do with no smoke on start up...any info on this would be excellent...thanks in advance
    mods:
    invidia catless downpipe
    cobb intake
    nameless axleback
    tune:
    torqued performance stage 2 map...
    third gear pull from 2500-redline
    https://docs.google.com/spreadsheet/...nc&usp=sharing
    Jan 2012
    Philly Area
    Did you send the logs to Eric?
    - Will
    Jun 2012
    NJ
    Hey, just to let you know. I have a couple of friends that is running this setup and they ran into issues.
    The issue is your TB to IC hose. This became loose because you have higher boost now.. Check it.. If it's loose remove the condoms and just replaced with clamps..
    Good luck!
  5. #4
    Jun 2012
    NJ
    DP
  6. #5
    Registered User Convictus's Avatar
    Apr 2013
    Houston, TX
    Check out this recent link which seems to be common.
    12 Wrx Stage 2 lost power
    I also had a subsequent complication after fixing this hose.
    I ordered an aftermarket replacement and installed. Immediately all issues seems better but not fixed. Over the next few days the issue slowly came back. So I assumed the there was still a leak. But I assumed wrong after a smoke test there was no issue so i decided to bite the bullet and buy a custom tune to replace my AP stage 2 map. They couldn't get a baseline because my car was running super lean. Luckily i only drove it for a few days like that but still very dangerous to the engine i understand.
    So apparently I failed to do something with the AP when fixing the boost leak that I did not read anywhere. Perhaps a learning function in the ECU for when i was leaking boost or just my lack of experience in following through on a repair. Either way glad it is fixed. Now to plan my next round of mods!
  7. #6
    Apr 2013
    Houston, TX
    double post oops
  8. #7
    Jun 2012
    NJ
    Quote Originally Posted by Convictus View Post
    double post oops
    Lol happened to u as well
