Limp MAP - 2004 WRX
Results 1 to 3 of 3
This is a discussion on Limp MAP - 2004 WRX within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Throwing new 1000cc injectors, 16G tubro and intercooler upgrade on the 2004 EJ20 WRX and need a limp map to ...
    Registered User KenFerrari13's Avatar
    Jun 2012
    Harrisburg PA
    Limp MAP - 2004 WRX
    Throwing new 1000cc injectors, 16G tubro and intercooler upgrade on the 2004 EJ20 WRX and need a limp map to get to the dyno shop? Checked out COBB and nothing to be found on there free opensource maps. Help!!
    The shop you're getting the tune from should provide it.
    Resident Tuner @ WTF Tuning
    Registered User bbrock171's Avatar
    Sep 2011
    Northern Virginia
    Quote Originally Posted by KenFerrari13 View Post
    I'm in the same boat. Injectors and turbo upgrade, and need to drive quite a ways to get to the shop. From what I've read to get a baseline on the injectors started at a minimum you need to change the injector scale value based on the size injectors and latency values depending on which injectors you have. Then you have to fine tune the scale based on fuel trims (sum of AF Correction 1 and AF Learning 1), and for larger injectors might need to adjust cranking IPW and tip-in enrichment as well. As far as the turbo, I would just stay completely out of boost if you're going to drive it for a short period untuned. I *think* it's much more involved...boost targets, turbo dynamics, wastegate duty, maf calibration, etc. etc. etc. I'll probably just have my car towed if they don't give me a map to get there on.
    I really want to learn how to tune my own car. 2yrs of research and I still have so much to learn, ugh.
