Data logs
Results 1 to 9 of 9
This is a discussion on Data logs within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hi, Capture some logs last night just wondering how they look? I also noticed the car surges when on boost..its ...
    Feb 2013
    NH
    Data logs
    Hi,
    I also noticed the car surges when on boost..its not a smooth pull..
    13 wrx on stage 1 normal Westgate
    Thanks for the help
    https://docs.google.com/file/d/0Bz9z...it?usp=sharing
    FYI, two of the logs are the same CSV file...
    That said, something caused the car to pull timing via FLKC, but as you progress through Datalog5 and Datalog7, you can see the ECU is adding timing back in.
    There is no real boost oscillation, so your description of "surging" could be your misunderstanding of how a F/I motor operates. Where in the RPM range does it not feel "smooth"?
    Resident Tuner @ WTF Tuning
    Registered User jsBLwrx's Avatar
    Oct 2012
    MD
    EJ, op could be referencing the wastegate cycle which can be unnerving at first....
    Quote Originally Posted by jsBLwrx
    Exactly what I'm referencing in my last part.
    Feb 2013
    NH
    Ok what you saying is the westgate was releasing the boost
    I thought I felt the surge also without being in the boost around the 3k rpm range or at very low boost today
    Quote Originally Posted by 13psi-
    There's a surge when the turbo kicks in. It's completely different from N/A acceleration; I think what you're feeling is normal.
    Oct 2012
    MD
    ^^^ +1
    Feb 2013
    NH
    The surge i felt was like if the lights where flicking before they went out bright then dim then bright and so on ...if that explains it any better…
    Here is a new log that I took yesterday..
    Moderator Donkey's Avatar
    Da boonies,Va
    Probably some "boost oscillations". Hard to tell due to Cobb's poor datalogging resolution. A "Protune" would fix that.
    2002 FORESTER S
    1998 FORESTER S
