Results 1 to 2 of 2
This is a discussion on First datalog for 13 WRX - Cobb AP - thoughts please! within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hi All: First datalog Car; 13 wrx limited. Running 93 0ctane shell Mods: Cobb AP - Stage 1 + Cobb ...
    Mar 2013
    Central NJ
    Hi All:
    First datalog
    Mods: Cobb AP - Stage 1 + Cobb SF Intake
    Map: Cobb non-california 91 + SF
    Parameters - 46 degrees out - WOT from 3k RPMs - 6K rpms in 3rd gear.
    https://docs.google.com/spreadsheet/...aZjJYQmc#gid=0
    link should be open to all.
    Thank you anyone who participates in this thread!
    2013 WRX Limited Silver. Stage 1 l+ Cobb SF, Short Shifter, 20/50 Tint.
    Logged 17.45 PSI @ 4200. Live Data'd 18.0 max.
    You know about keeping the parameters short/concise, but you're missing some important ones, and have some useless ones. Get rid of AF Learning for anything WOT (it's disabled), and get rid of IAT (verify that before the run, if you want), but otherwise, they're wasting bandwidth. Add throttle opening angle and boost error.
    I prefer to start the logging runs earlier in the RPM band; 2K-redline. 3rd gear is what you want a full log to be in, but I also like to see some logs in 4th gear, as well. I'm not sure how the gearing matches up, but you want to do a similar log in 4th up to 4.5-5K.
