Results 1 to 10 of 10
This is a discussion on Cobb Accessport Question within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I plan on going stage 1 soon.. After I do some initial data logs to make sure everything is ok, ...
    Registered User chris law's Avatar
    Oct 2012
    Berlin, CT
    I plan on going stage 1 soon.. After I do some initial data logs to make sure everything is ok, how often should I log after that?
    Whenever you want. I typically log two to three times/month. Then again, I've had my tune pretty finalized for a long time...
    Oct 2012
    Berlin, CT
    Thanks for the Reply- I guess what i'm getting at is-- if the ots map I go with works perfect when i first flash.. is there a chance it won't agree with my car down the road at some point?
    Quote Originally Posted by chris law
    Is the weather and other conditions (e.g., altitude) you drive on always the same?
    Apr 2007
    8000' up in Colorado
    Most likely the car will work fine on day 1000 if it works fine on day 1 unless you have something else go wrong (i.e. like a boost leak or other problem). Most people never data log after flashing their cars and never have any problems with their tune.
    Scott
    Quote Originally Posted by teflon_jones
    Yes and no. There are variations in driving conditions that can make the map perform poorly in some circumstances.
    Many people don't log their car after flashing a base map and don't have an issue like a blown motor in the time they own the car; that doesn't mean that the map is operating properly, and often times, they wouldn't know it. The people who choose not to datalog, are often the kind that wouldn't know knock if they heard/felt it.
    Oct 2012
    Berlin, CT
    good info, thanks
    Mar 2013
    Central NJ
    Chris. For what it's worth u can 1 open box 2 install 3 learn to use 4 Data log. 5 Upload to comp then here and 6 get feedback in about two hours including figuring out how to work everything. I installed on Tuesday night, took Wednesday off to put some miles on it and then log. Thursday I have a nice log and a noticeably faster, higher boosting (data proven) car.
    2013 WRX Limited Silver. Stage 1 l+ Cobb SF, Short Shifter, 20/50 Tint.
    Logged 17.45 PSI @ 4200. Live Data'd 18.0 max.
    Registered User Kam91's Avatar
    Jul 2012
    Ok EJ since you say weather and such can change how your tune works, then does that mean I should log often because the climate in my area changes a lot from summer to winter and sometimes we get freak weather during spring and fall where one day temps can be as high as 70 then drop to below freezing in 2 days...
    Quote Originally Posted by Kam91
    There is never a harm in logging to make sure everything is running properly. I logged my car quite a bit for a year dialing in my tune. Now, I just log randomly once in a while to do a quick check.
