This is a discussion on Torqued Performance Stage 2 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Well boost leak should be fixed, sent Eric the new logs. Now time to see what he says....
2013 SWP WRX Sedan
Malvern, PA
Hillside, NJ
Invidia Catless Downpipe Torqued Performance Stage 2
Ill be upgrading to a perrin fmic once i have funds for a tomei arms turbo.
2013 SWP WRX Sedan
Malvern, PA
Hillside, NJ
Don't waste your money. If you want to upgrade your turbo, just go rotated...Originally Posted by anpato
Dont want that big of a turbo though, wanna keep it stock location. But ive just recently started looking at rotated turbo kits so maybe I might just save up for a rotated setup.
2013 SWP WRX Sedan
Malvern, PA
Hillside, NJ
Just got an email from Eric, logs look good, car is performing good. Ill be emailing him some new logs in a few days once the ECU learns.
2013 SWP WRX Sedan
Malvern, PA
Hillside, NJ
You don't have to go obnoxious with the turbo size. GTX3071R is a fantastic turbo for the 2.5L motor with regards to DD-ability. The Tomei turbos are overpriced for what you get from them (similar to the APS turbos on previous MYs). While a "rotated" setup seems expensive, when you factor in that you can sell many of the aftermarket parts you buy for a SL setup, the price difference is negligible. With a rotated setup, you can have a more aggressive tune with the same safety margin, as the system is more efficient.Originally Posted by anpato
I was looking at a blouch 20gxt-r also, I have seen a newer sti with a rotated setup and wow. He said he was still on stock internals pushing 447whp.
2013 SWP WRX Sedan
Malvern, PA
Hillside, NJ
A comparable stock vs rotated setup, the rotated setup should be able to run a more aggressive tune vs the stock location. With any worthwhile turbo upgrade, you're looking at a motor build, and you'd be happier with a rotated setup, to be honest...Originally Posted by anpato
Gahhhh your convincing me to spend money! hahaha Eventually the motor will be rebuilt with all new internals. But until then Ill settle for a new turbo on a mildly aggressive tune. But your definitely convincing me to go rotated!
2013 SWP WRX Sedan
Malvern, PA
Hillside, NJ
