Boost target...
But then you gotta make sure your hitting your Max Waste Gate Duty.
But at 2-3 PSI you might be knocking.... so then double check your Primary Open Loop Fueling and richen up if needed. If that doesn't work... Check your Base Timing and Knock Correction Advance Max.
Sound easy enough man? Good! Try not to blow up your engine man!
Orange = sarcastic font = ignore post.
LinkBack URL
About LinkBacks
