Difference's and Pro's and Con's
Results 1 to 15 of 20
This is a discussion on Difference's and Pro's and Con's within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I have been looking into getting a Cobb AccessPort for my 02 WRX, i have been using a friends OBD-II ...
    Registered User SubaruDewed's Avatar
    Jun 2011
    I have been looking into getting a Cobb AccessPort for my 02 WRX, i have been using a friends OBD-II reader to constantly delete a CEL that comes up since i replaced my old radiator and thermostat, anyway thats off the subject. I recently saw a Actron CP9185 for half the price of the Accessport. Now i know the OBD-II reader will not do near everything the Accessport will, but my question is, will the accessport do what this device does? would it be a waste of money to by this and then by the accessport also?
    May 2007
    orlando flawduh
    An access port not only reads/clears codes but its a handheld tuning device also.
    desiree
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    If you have no plans to tune the car, a simple scan tool will suffice.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Oct 2011
    Santa Ana, CA
    Re: Difference's and Pro's and Con's
    I'd post that code and get that fixed first... just my 2c.
    Posted from a fone.
    Palmyra, NJ
    Quote Originally Posted by UEDan View Post
    Posted from a fone.
    Trudat yo!
    Jun 2011
    Trudat yo!
    I know exactly what the code is, it is PO128 which says to check thermostat/cooling system, the reason this pops up is because i replaced my stock radiator w/ a fully aluminum race radiator and a lower temp thermostat, so in turn my engine doesnt hit the required temp in the required amount of time, which is what was expected with the installation of these parts. This is not the problem which is why i didnt go into it. I do plan on doing some tuning to the car, my whole question was will the tuning tool do everything the OBD-II will or would i benefit from buying both?
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by SubaruDewed View Post
    In that case, the Accessport will do everything you need. It's an OBD-II/CANBUS reader + tuning tool all in one. No sense in getting both devices.
    2007 Outback 3.0R wagon
            MainFrame's Avatar
    Austin, TX
    Just as long as you do understand that it IS a problem and that you should put the correct temp thermostat in your car to prevent further damage to your engine. Some people actually think it's good for their car to run under temp, which is of course is not the case.
    Jun 2011
    Not the problem thanks. For a turbo charged car that runs over normal temp to begin with an produces more NOx because of those higher temps a lower temp is better for the car, and emissions, since it wont be as low to effect the HC or CO2 readings.
    zax
    zax is offline
    Nov 2008
    That is not at all true. Your car has an operating temperature for a reason. You're familiar with CTE of materials? The motor's tolerances are optimum at the operating temperature. At a lower temperature, the piston rings have not fully expanded to the match the cylinders, and the bearings have not expanded to fill the crank pins. Put it this way: if a 160 degree thermostat has only positives and no cons, why had Subaru not put one into the car from the factory?
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
    Wait -- you've measured reduced emissions after removing the thermostat and replacing with a lower temp unit? How much lower were the NOx data? What happened to CO? Same ambient temps? Post the data if you have them, I'm all for reduced emissions.
            MainFrame's Avatar
    Austin, TX
    How high over normal temp was your car running? I would definitely investigate the cause of the overheating rather than just trying to put a band aid on it (lower temp thermostat). Generally, a lower temp thermostat shouldn't have any effect on overheating anyways (unless the cause was a faulty thermostat in the first place). For what it's worth, optimal operating temperature for a WRX/STi is anywhere between 190°F and 210°F.. if your engine is not reaching those temperatures in a timely manner, then it is undergoing unnecessary damage.
    Jun 2011
    wow this got off topic fast, and mostly my fault with the wording of some of what i posted. My car was never overheating, i cracked my stock radiator and replaced it with an all aluminum radiator and a Grimmspeed Thermostat. That thermostat does not run my car under normal operating temperatures, i know this because my temp gauge will still go up to the "normal" temp spot and not go over. i do believe it does take longer, with the combination of the better radiator and thermostat, to reach that this temp, especially early in the morning on the freeway, but not effected to much during mid day in town. I believe this to be due to how much more air flow im getting while on the freeway and how cold it is outside (30-50) compared to stop and go in town at around 70-90 degrees outside. Anyway, Thank you for the answer i was looking for Rambo.
    Registered User Mr.Tran's Avatar
    Feb 2013
    If u strictly want a code reader buy one off newegg for $20.
    Moderator Donkey's Avatar
    Da boonies,Va
    The AP is defiantly not a true OBDII scanner. Can't count how many times some one has posted about the AP displaying "?????" for the code.
    2002 FORESTER S
    1998 FORESTER S
