Results 1 to 11 of 11
This is a discussion on Taxtrix 2.0 Openport within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So hopefully someone can help. I recently purchased the tactrix openport 2.0 and I cant get RomRaider to recognize it. ...
    Registered User anpato's Avatar
    Jun 2012
    So hopefully someone can help. I recently purchased the tactrix openport 2.0 and I cant get RomRaider to recognize it. EcuFlash recognizes it fine, but Ive been unsuccessful in getting romraider to show the ecu connected.
    2013 SWP WRX Sedan
    Malvern, PA
    Invidia Catless Downpipe Torqued Performance Stage 2
    Texas, United States
    What operating system are you using? And are you sure you have Java fully up to date?
    Jun 2012
    Just reinstalled everything with latest java, could it have to do with me using windows 8?
    2013 SWP WRX Sedan
    Malvern, PA
    Dec 2012
    South Jersey
    Quote Originally Posted by anpato View Post
    I would assume Windows 8 isn't the issue since ECUFlash sees it. You try installing it outside of the 'Program Files (x86)' folder? Assuming your using Win 8 x64
    Jun 2012
    Im running x64, no i havent tried installing out of that folder, but why would the folder make a difference if its installed on the C drive.
    2013 SWP WRX Sedan
    Malvern, PA
    Dec 2012
    South Jersey
    I know the program files folder has different permissions. You can look here for more info that might help.
    I run XP on my tuning laptop so I'm not much help trouble shooting.. I know someone recently was having similar issues and it turned out they had installed 64-bit Java, not the 32-bit version that is required.
    Jun 2012
    Ill give the 32bit java a try tonight and Ill post back if Im still having trouble.
    2013 SWP WRX Sedan
    Malvern, PA
    Moderator Donkey's Avatar
    Da boonies
    2002 FORESTER S
    1998 FORESTER S
    Jan 2012
    Philly Area
    Do you have the correct definitions file?
    - William
    Jun 2012
    Figured out the problem gentlemen, wrong definition file, whoops...
    2013 SWP WRX Sedan
    Malvern, PA
