Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
This is a discussion on COBB Tuning within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by zax A wideband O2 sensor is one of the most important installs if your car is modified ...
  1. #31
    Mt. Laurel, NJ
    A wideband O2 sensor is one of the most important installs if your car is modified IMO.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Not if you don't know what your looking at or know what it means...
  2. #32
    zax
    zax is online now
    Tony Vargis zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: COBB Tuning
    Then you shouldn't be modifying your car
    Sent from my Nexus 7 using Tapatalk HD
    Facebook me here
  3. #33
    Mt. Laurel, NJ
    Quote Originally Posted by bz24 View Post
    So do I need just the sensor or the actual gauges also? I just don't have a place to put the gauge because I already have those other two gauges in my SMY cluster.
    There are tons of places you can mount gauges....it's not hard.
    Clock pod? Buy a single gauge cup and just put it on the dash? Vent pod A-Pillar Pod? Passenger A-Pillar Pod? Subiegal Pod? Rearview Mirror pod? Ashtray pod? Single DIN unit Pod?
  4. #34
    Negative Nancy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    --MBR - STORE--
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
  5. #35
    Feb 2012
    Orem, Utah
    Quote Originally Posted by rage-wrx View Post
    I still and to get air flow into my car. I just want something that will be stealth like the SMY cluster. I don't want it in an annoying spot that I will get bugged with soon. Any other ides?
  6. #36
    Aug 2010
    Yonkers/NYC
    The MBR pod still retains the ventilation for AC/Heat.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
  7. #37
    May 2010
    Pittsburgh, PA
    I agree.
    2011 STi Build Log
  8. #38
    Nov 2012
    Ohio
    My 2013 WRX makes 265 hp stock. If I buy a Cobb access port and go stage 1 with no other mods and run 93 octane fuel only, what hp should I expect to see. Any other advantages?
  9. #39
    zax
    zax is online now
    Nov 2008
    Re: COBB Tuning
    Quote Originally Posted by Callahan View Post
    The Cobb map notes explicitly state the answer to the question you've posed. I suggest you read the map notes.
    Facebook me here
  10. #40
    Nov 2012
    Ohio
    I have an iPad. Cobb does not allow safari to access this map note. Can anyone post this answer as previousy asked?
  11. #41
    zax
    zax is online now
    Nov 2008
    Re: COBB Tuning
    Facebook me here
  12. #42
    Nov 2012
    Ohio
    Thank you
