Results 16 to 30 of 42
This is a discussion on COBB Tuning within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by bz24 Which wide and O2 would you recommend? There are 3 typical options: 1.) AEM UEGO 2.) ...
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by bz24 View Post
    1.) AEM UEGO
    2.) Innovate LC-1
    3.) PLX WBO2
    Zeitronix also produces WBO2 sensor IIRC, but I haven't seen one in some time.
    If using Cobb AccessTuner Race to datalog WBO2, I would stick to AEM or Innovate.
    Facebook me here
  2. #17
    Feb 2012
    Orem, Utah
    You can add a down pipe with a nameless exhaust, without removing the axle back. I started with a Nameless axle back actually on my 5 door. When their mid-pipe came out, I bought one. I use an invidia catless down pipe. You can piece your own system together, just be careful to verify fitment between the various pieces.
    So the fitment between my Nameless axle back and the Cobb down pipe should work?
  3. #18
    Registered User Terminal Kuz's Avatar
    Aug 2012
    SoCal
    The Cobb downpipe will not reach the axleback. If you had a catback then yes it would but with the axleback theres still the portion from the midpipe to axleback you will need to buy or keep if you want. The Cobb downpipe replaces the stock downpipe and midpipe in one piece.
    2005 WRX (Silver) SoCal Subie
    Blobeye Syndicate #1093
    http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
    http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
    Mikie13-Spend money on hookers and blow. That's a better intake.
  4. #19
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by Terminal Kuz View Post
    I ran the stock mid pipe with my axle-back. I then swapped out the stock mid pipe. I then swapped out the down pipe for an invidia.
    I think all three are interchangeable on an 08+ hatch at least. Does the cobb down pipe differ in length from the invidia? The invidia took out both cats in there, so I wouldn't imagine the Cobb was any longer to include them.
    As a warning, I believe the Cobb does taper down to 2.5" towards the mid pipe. I don't think this will be an issue if you are re-using the stock mid pipe section, but if you upgrade to a full 3" mid pipe, you'll need to get a different down pipe.
    2011 STi Build Log
  5. #20
    Mt. Laurel, NJ
    IIRC, the Cobb DP tapers to 2.5in at the flange though...mating up to a 3in CBE isn't terrible as the smaller output going into a bigger inlet isn't as much prone to an exhaust leak. At Stage 2 power levels, the 2.5in taper isn't of much concern in regards to bottlenecking either.
  6. #21
    Feb 2012
    Orem, Utah
    I'm honestly not sure how the Cobb EBCS fares. I do, however, know first hand that my GS EBCS is a complete PITA to tune. It took over 15 iterations to hit and hold my target boost properly on my stage 2 tune. And I don't think I ever got it 100%... as I upgraded my turbo in the next few weeks. I've heard the Perrin and GM units are much easier to tune, but I have no first-hand experience.
    What's the main difference between stage 1 and 2? How do you know which one you can do? Do you have to use stage 1 for a little before you go to stage 2?
  7. #22
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    AccessPORT Off The Shelf Maps
    the map notes from cobb will tell you exactly what you need.
    cliff notes:
    stage 1: tune
    stage 2: downpipe & tune.
    you can either go stage 1 first, then stage 2
    or go straight from stock to a stage 2 setup
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
  8. #23
    zax
    zax is offline
    Nov 2008
    Stage 2 involves installing a 3" downpipe.
    Facebook me here
  9. #24
    Feb 2012
    Orem, Utah
    So I just purchased my AP, SF Intake, AME O2 Sensor and Cobb downpipe. I can go to stage 2?
  10. #25
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
    Sure sounds like you can.
  11. #26
    Feb 2012
    Orem, Utah
    I'm down like chinatown. Thanks.
  12. #27
    Nov 2012
    MAINEiac
    Like these guys said, the only thing you need to go stage 2 is the aftermarket downpipe and stage 2 cobb map.
  13. #28
    Feb 2012
    Orem, Utah
    1.) AEM UEGO
    2.) Innovate LC-1
    3.) PLX WBO2
    I already have a SMY cluster, Defi boost gauge, and an Defi oil gauge. Would you still say to get the WBO2 sensor? Where could I put it?
  14. #29
    zax
    zax is offline
    Nov 2008
    Re: COBB Tuning
    A wideband O2 sensor is one of the most important installs if your car is modified IMO.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
  15. #30
    Feb 2012
    Orem, Utah
    So do I need just the sensor or the actual gauges also? I just don't have a place to put the gauge because I already have those other two gauges in my SMY cluster.
