Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
This is a discussion on 13 Wrx Stage 1 Datalog Help within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by SubiEj255 I thought a typical log was from 2k rpms to redline in 3rd gear in 5 ...
    Registered User garzdos's Avatar
    Feb 2013
    Oregon
    Quote Originally Posted by SubiEj255 View Post
    I thought a typical log was from 2k rpms to redline in 3rd gear in 5 speed cars and 4th gear in 6 speeds.
    I don't think you need to shift gears while logging. One pull is fine.
    ^^^This.
    Cobb recommends starting the log at about 2500 RPM in 3rd gear (5 MT) and going up to red line WOT. No need to log your shift to 4th.
  2. #17
    Mar 2013
    Central NJ
    for what it's worth, I have the same setup as you and am running the 91 map while using 93 gas. Maxing the boost at 17.45 instead of your 18.1, but not having any of the small "problem" you are having.
    2013 WRX Limited Silver. Stage 1 l+ Cobb SF, Short Shifter, 20/50 Tint.
    Logged 17.45 PSI @ 4200. Live Data'd 18.0 max.
