Results 1 to 6 of 6
This is a discussion on 13 WRX Stage 1 datalog within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Just wondering if you guys can look over this and make sure everything seems right. Target boost for my map ...
    Registered User superdonkey23's Avatar
    Dec 2012
    Just wondering if you guys can look over this and make sure everything seems right. Target boost for my map is 17.5 psi +/- 1. I also have the Cobb SF intake installed. Had to stop a little sooner than i wanted because i ran out of road :/
    https://docs.google.com/spreadsheet/...nUtTjV6ZlRIOGc
    Dec 2012
    South Jersey
    Didn't make access public
    Dec 2012
    Quote Originally Posted by rquinn19 View Post
    Sorry about that, fixed.
    What you posted isn't bad (although, incomplete); no FBKC/FLKC, and boost is in line. Instead of AF Learning (which isn't applicable in WOT), add DAM to your log and try again.
    Dec 2012
    Will do. Appreciate the help btw
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    What EJ257 said. Change some of the parameters then repost; more specifically add DAM.
    A car is only as good as its driver
