Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
This is a discussion on 02 wrx won't start after reflash within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Ok, checked the relay and its still good. Car is running pink injectors. When the car was first started the ...
    Dec 2011
    Ok, checked the relay and its still good. Car is running pink injectors. When the car was first started the shop noticed that the fuel pump was running at 80 psi. so we haven't started it since. Hoping that the new map would tone it down.
    Noticed that the battery is pretty weak. Going to get a new one and see if that helps.
  2. #17
    Texas, United States
    Shouldn't flash with a weak battery. .if your car battery dies during the flash then the ECU will brick.
    The map shouldn't have anything to do with fuel pressure. . That is a function of the fuel pressure regulator.
    Also, if you have 565cc Pink injectors, then the stage one map you were trying to flash is not made for your car. Stage one maps have stock injector scaling.
  3. #18
    zax
    zax is online now
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: 02 wrx won't start after reflash
    Quote Originally Posted by dash05 View Post
    That doesn't seem correct. How did the shop determine the fuel pressure?
    Almost happened to me recently...
    Sent from my Nexus 7 using Tapatalk HD
    Facebook me here
  4. #19
    Dec 2011
    They got the fuel pressure off of the diagnostic machine they have.
    Where is the pressure regulator located cause neither the shop or I can find it?
  5. #20
    zax
    zax is online now
    Nov 2008
    It's located off the passenger side fuel rail. Although I seriously question the shop's analysis. More so if they cannot locate the FPR. Per my understanding, the ECU cannot read the Fuel Pressure directly, only the Fuel pump duty cycle. I'm not sure how they would have determined the pressure at the location of something they cannot find.
    Facebook me here
  6. #21
    Dec 2011
    Going to look for a stage 2 map and a new battery. I'll report back right after. Thanks everyone!
  7. #22
    Oct 2011
    Santa Ana, CA
    I had this problem when I first flashed my car. Long and embarrassing story short.... I had blown a fuse.
    Posted from a fone.
  8. #23
    Your car is not stage two, so that map wouldn't work either. You already said the car has different injectors. All off the shelf maps are made to only work with stock injectors.
    I'd have to agree with Zach, this so called shop sounds shady and incompetent if they can't even locate the fuel pressure regulator. I'm not sure what this "diagnostic" is that they did. . The only way to read fuel pressure is to install a fuel pressure gauge. AND, if your static pressure really was 80psi you would have to get that fixed before you could even consider tuning, let alone driving the car. If a shop cannot even locate a FPR they have no business working on cars.
    Why exactly are you running after market injectors in the first place?
  9. #24
    Dec 2011
    I got the car with them installed already. The car came with an exhaust, intake, aftermarket boost controller, turboxs UTEC (Which was removed), pink injectors and a VF30 turbo. I believe the previous owner was running a FMIC also but later removed it before selling.
    Guess I have to hunt down stock injectors now.
  10. #25
    Dec 2011
    Anyone have a set stock injectors they are looking to sell?
  11. #26
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    I'm confused. Do you still have the vf30, boost controller, exhaust, etc? Or is all of that uninstalled?
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
  12. #27
    zax
    zax is online now
    Nov 2008
    Just use ATR to rescale your injectors.
    It's no wonder the car wouldn't start... if the car had 565cc/min injectors and the map scaled to 420cc (stock), the pulse width is far too short. Actually, it's rather a GOOD thing your car didn't start.
    Facebook me here
  13. #28
    Dec 2011
    Quote Originally Posted by wrxtreme06 View Post
    Yes I still have them. Only thing uninstalled was the UTEC.
  14. #29
    Dec 2011
    Ok, going to read up on rescaling. Thanks
