This is a discussion on AccessPort question (yes i read sticky) within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by rurso01 Technically what I'd be doing wouldn't be the reasoning for problems arising in the car. If ...
There would be no reason for you to feel the need to reflash back to stock unless there's an issue that could be attributed to said reflash (they can't attribute a reflash to you windshield wiper motor dying). By trying to deceive the dealership into doing work you're not entitled to, you're committing fraud.Originally Posted by rurso01
My car is modified, but never got warranty work done, and I wouldn't have tried to hide that my car was modified.
Facebook me here
Originally Posted by Mikie13
2013 SWP WRX 5-Door
2005 OBP WRX 4-Door SOLD
That's great. I got a LGT 05 and always worked on it myself. Just replaced brakes, rotors, and wheel bearings. Cheaper and more fun!
I only got 1000 miles on my WRX and it's about time to go stage 1!! I'm glad to here that it made your car better. I just needed some assurance.
Yeah I was also concerned about the warranty. But you know Ive been driving subie's on and off since
1987 :knocking on wood: and never had a mechanical issue other than normal wear items. As for the AP.. I picked one up here
on our great forumused for 400. Just make sure if you buy used that its unmarried/uninstalled from
who ever used it last. You tube has some great vids for using and installing the AP. I am very satisfied with the power
and smoothness for now![]()
Rod
2012 DMG WRX base Sedan Cobb S1 93 Octane
Older than dirt Mob#1
"Just remember, with great power comes great responsibility" - rarrior
well, i just got my stage 2 upgrade done on mhy 2013 that is three months old.... it's a risk on such a new car but it is a calculated risk for every owner IMHO to mess with the car or not
so far, i am extremely impressed with the power, but i'm also very conscientious of the motor and the tranny
also, i'm assuming the installation did not go as well as the shop intended: starting from the day 3 to today (day 6) since the work was done, i'm noticing exhaust fume coming through the vents in the car, and it appears to be coming from the top of the car - location where the TBE (CATTED invidia downpipe to turbo) mates to the turbo..... it's got worse as the number of days since the post installation
i'm also hearing through the intake (cobb sf short ram intake with box) definitely audible "air fluttering" sound.... imagine a sound when a filled balloon is emptied minus the high shrill note..... umm may be a disgusting elongated dry fart LOL. this only happens during a high load, low rpm 10+psi threshold (like going 50, in 5th and 3/4 throttle)
Well, point being, i'm scheduled to take the car in again to the same shop to diagnose the issue on Monday to check all the fittings and gaskets on the install.....
If you don't have a private driveway to work on your car, just like me, then consider spending additional personal time investment to TLC the mods until it's all good..... I wish I had access to a driveway of my own to make minute adjustments.... :-\
On a positive note though, I can not go back to the stock tuneThe stage 2 is just so much better in every other way - Cobb OTS lwg tune with a target boost of 18.5 (quote from Cobb)
good luck with your decision to mod or not, but it is a risk you have to take....![]()
That's a perfectly reasonable assessment on their behalf. The additional power put out by the motor caused undue stress on the transmission, leading to premature failure.
If you're concerned with warranty work, keep the car stock; live up to your half of the contract. If you choose to modify the ECU to get more power, Subaru has every right to deny a powertrain claim.
I offered in my first post in the thread.Originally Posted by zax
That's strange because I just got an etune recently and on the first couple of datalogs before we adjusted the tune I was showing fine knock learning but no feedback knock correction. Also, the way Cobb's website explains these datalog parameters it sounds like fine knock learning can in fact occur without feedback knock correction.
Yes, you are correct in the instance that the IAM need not further increment and knock event registers over a specified RPM/load range as per the KC tables. I apologize for the confusion, as what I meant to say is it's unlikely that there will be no recorded FBKC in that range (at any other time) when FBKC is not disabled, but it is is possible for the ECU to utilize history data.
RomRaider • View topic - Subaru's knock control strategy explained
That should be a sufficient read.
Facebook me here
It is entirely legal for those of us that own the vehicle (i.e. not a lease) to re-program the ECU all day long. Nothing illegal about that. However, Subaru is known to deny warranty claim when things are modified. And that in turn is also legal ( even if we don't like it). Reflashing to original setup and saying it was never changed probably constitutes cheating. A stage 2 would entail intake, exhaust, probably turbo, then you're way past reflashing to stock, and quite obvious. So a stage1 tune should be fine and might not even upset the stealership since it's not openly visible. In that case I'd guess it would depend on what exactly went belly-up.
I would say Ruh Roh is right on: leave the power mods for later, maybe something like 10KMls, when you know it's good in that department. I'm not sure the 5yr warranty is worth it, here you run into the limitations of that. Anyways, upgrading the suspension and brakes will make it a way more fun car. It's very powerful right out-of-the-box anyways, and with a little help it gets to be real fun to drive. So what if a stage2 can out-accelerate you. You're already way past the normal Hotokias...
StageII is a turboback exhaust and reflash.Originally Posted by Ingo
