Accessport stage 1 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Accessport stage 1 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Just an update I changed the downpipe and stage 2 flash but had the exact same reaction as before I ...
    Nov 2012
    Dover, Pa
    Just an update I changed the downpipe and stage 2 flash but had the exact same reaction as before I have a stock ebcs purchased and should be on the way soon in the meantime I went back to stock ecu and it seems to be running decent I also noticed while I was under the car removing the downpipe that the uppipe is catless which makes me wonder if the previous owner had any kind of tuning done
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    a catless uppipe doesnt need any tuning. you should actually thank the previous owner for saving you a boatload of work and a lot of banged up knuckles
    Nov 2012
    Dover, Pa
    ^^^^very true I've found the turbo back Cobb exhaust catless uppipe Cobb short throw shifter turbo xs fuel rails the manual boost controller and an spt intake, maybe I should just forget about the accessport and sell it and get a pro dyno tune it would probably be way more beneficial
  6. #19
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Skelly View Post
    All of that stuff requires a custom tune, which makes an AP virtually useless.. unless your tuner only does AP tunes.
  7. #20
    Nov 2012
    Dover, Pa
    Unfortunately MainFrame I do understand that but at least I figured out why the stage 1 or stage 2 map doesnt work
  8. #21
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    And here's another one that should look into the open sorce... And I'm almost sure Eric with TP would be able to help and at a reasonable cost.
  9. #22
    Nov 2012
    Dover, Pa
    Who is Eric with TP? and i've been looking into open source but not sure where to start, but not extensively so I know search the forums before anyone yells at me. I didnt realize before I got the accessport how stock your vehicle has to be, live and learn I guess, I think protune is what I'm going to do I know there are a couple of good places fairly close to me then I will really look into open source for future performance mods I may do
  10. #23
            MainFrame's Avatar
    Austin, TX
    Yeah, I would look for a local Subaru performance shop with a good reputation and ask if they do Open Source tuning. You could talk to Eric at Torqued Performance for getting an e-tune, but you would need to purchase a Tactrix cable, and even then you would only be getting a tweaked base map. A real tune for your specific car is where it's at.
  11. #24
    Oct 2011
    Santa Ana, CA
    Tried it. Erik won't do an e-tune with older models ='(
    Too many unknown variables due to age of car.
  12. #25
            MainFrame's Avatar
    Austin, TX
    Yeah, he only does 08+.. for some reason I was thinking the OP had a newish car.
    There are plenty of other people that do quality e-tunes. Either Phatron or Keith @ AWDTuning would have no problem doing it. Hell, Matt (EJ257) might even do it.. but it's a lot easier to get a more comprehensive tune in person.
  13. #26
    Mar 2012
    I knew it, but somehow disregarded that Torqued Performance does only 08+. The opensource is still a valid option for logging and generally seeing what's going on. And a lot cheaper than AP. Not as flashy/pretty, but hey... And nowadays most people have a laptop (doesn't have to be fancy, after all.) An individual tune is certainly a good way, it would after all be specific for the car in question.
