OP2 Stand Alone logging woes. - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
This is a discussion on OP2 Stand Alone logging woes. within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; According to ECU flash the can patch is running and I have ver 1.44...
  1. #31
    Registered User Rummie's Avatar
    Mar 2012
    Oklahoma somewhere...
    Not as many parts left over this time... what am I missing?
  3. #32
    Jan 2013
    We've just released a new version to correct the can patching and also to show the missing mem model info under the ROM info section. Sorry about the trouble. If you find any other errors with EcuFlash you can always contact us at support at tactrix.com. You can download the new version (1.44.3721) here:
    Download EcuFlash 1.44
  4. #33
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by Rummie View Post
    Does that mean your issues are resolved? Or still having issues with the RAM parameters? If you are still having issues, compare some of your RAM parameters to mine out of the one I posted above. You should be able to take all the parameter names/scaling/address lengths verbatim, and only change the addresses to match your ECU. Feel free to post it up on google docs or on here otherwise, I will compare it as well and take a look. It's frustrating to get this stuff going at first - trust me though, its definitely worth it.
    Quote Originally Posted by MikeyPSF View Post
    Great! I had briefly heard about that. Good to see the support =)
    2011 STi Build Log
  6. #34
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Good deal, I actually just updated earlier today. Thanks!
    2007 Outback 3.0R wagon
  7. #35
    Mar 2012
    Last I checked I was still having issues with a couple parameters but I am just now updating versions and will give it another go this weekend to see what, if any, issues are still present.
    Thanks for the update Mikey and no worries on any troubles, I am just cutting my teeth in all this so honestly if it went smoothly I wouldnt have learned a damn thing. I had fun
  8. #36
    Mar 2012
    also brushing up on my excel today and tomorrow... I'm sure I have a codekey around here somewhere
  9. #37
    May 2010
    Pittsburgh, PA
    I'd strongly recommend adding filter and freeze row to your "ribbon bar" hotkeys. Excel will map them to Alt + #. I took off save/undo etc since I know those hotkeys. Now when I open a large log, I can just hit Ctrl + A (to select all), Alt +2 (to filter), Alt + 3 (enter freeze frame menu), R (select top row)... Then its much easier to work with.
    Let me know what remaining issues you have with your config file. I brought my SD card in to work so I have my latest one to compare it to if needed.
    2011 STi Build Log
  10. #38
    Mar 2012
    Busy weekend but I managed to get some time to check out the new OP2 updates.
    Still only getting empty logcfg.out files for fbkc and flkc parameters. I delete those and it runs perfectly. 1 byte or 4 byte and the loggiing just shuts down entirely. What I used last...
    paramname = FBKC
    paramid = 0xFF686F
    isfloat = 1
    That is what is in my ECU specific definitions for the 1 byte. Am I missing something?
    I am getting numbers from this FLKC now. Just not FBKC
    paramname = FLKC
    paramid = 0x000199
    scalingrpn = x,0.25,*,32,-
