Results 1 to 9 of 9
This is a discussion on Attn Heide and Zax. within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Here is a data log from my drive home as you requested. https://docs.google.com/open?id=0B8b...kdSc3dlUFhiT00...
    Aug 2009
    Glendale, NY
    Attn Heide and Zax.
    Mt. Laurel, NJ
    biggest log evaaaaaaaaar (that's what she said)....and no actual WOT pull...
    I shouldn't respond since this thread is directed at other people, but...
    1) Shorten your log (multiple short logs are more useful and easier to interpret). 5000+ lines is rediculous.
    2) DAM is below 16. Something's off. When you first reflash, what is the DAM set at?
    3) Who did the tune?
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Yeah, I'm not seeing any pulls past 5,000rpm.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Aug 2009
    Glendale, NY
    This is tuned on the accessport. so i have no idea.
    Quote Originally Posted by silvercookie
    DAM is 15, which isn't a big deal, but it's not right. You may have a tank of bad gas or something. Keep an eye on the DAM and make sure it doesn't go any lower, and fill up at a different station next time. Reset the ECU and see what happens
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Yeah, as mentioned, DAM has incremented down. No FBKC really, which is a good sign. I'd keep a watch on the DAM, however.
    Also, how far are you along on the break-in period? I see the hardest you pushed the car was only 1.7 load. I'd say do the following:
    1.) Reset the ECU
    2.) Remove all other logging parameters except for: Calculated Load, RPM, Boost, FBKC, FLKC, DAM, and Throttle %. Perhaps also add IAT.
    3.) Get in the car, immediately do a 20-30 second log to record the default DAM
    4.) When DAM is 16, please begin a 60 second log hitting 2.0 load and featuring some tip-in
    As Matty said, perhaps it's a good idea to fill up with quality 93 octane ASAP
    Facebook me here
    zax
    zax is offline
    Nov 2008
    IAM is still 15... and you are getting some FBKC in the first log in a relatively high load cell (1.6). Not necessarily a cause for alarm, but I'd keep an eye on it. Make sure you reset your ECU.
    Facebook me here
