Results 1 to 8 of 8
This is a discussion on data logging within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Im new to data logging and tuning, recently i reflashed my 2011 wrx with a torqued stage 2 map. These ...
    Jun 2012
    PA
    data logging
    Im new to data logging and tuning, recently i reflashed my 2011 wrx with a torqued stage 2 map. These are two data logs i did recently and i just whant to know if the information is good or bad?https://docs.google.com/spreadsheet/...QR1E5SVE#gid=0
    Jan 2012
    Philly Area
    Google Drive Error. You need permission to access blah blah blah.
    - William
    Jun 2012
    PA
    my fault it should be ok to look at now
    Skip the AF Learning / Correction stuff. Download Learning View instead to show what AF Learning is.
    Don't log Engine Load Relative %
    Don't log Manifold Relative Pressure (PSI)
    Don't log Defogger switch
    Log:
    Target Boost
    Fine Learned Knock Correction
    Injector Duty Cycle
    Jun 2012
    PA
    Log:
    Target Boost
    Injector Duty Cycle
    I did log fine learned knock correction and injector duty cycle but my parameter lis doesnt have target boost
    Quote Originally Posted by josh_cooper
    Sorry, Feedback Knock Correction.
    Injector Duty Cycle (you logged WGDC, keep that as well)
    Boost Error
    Jun 2012
    PA
    ok thanks also i wanted to know if the numbers my car was showing are good or bad i need to have more experience before i ca decide that for myself haha
    Jan 2012
    Philly Area
    Quote Originally Posted by josh_cooper View Post
    You said you flashed "torqued stage 2," does that mean Torqued Performance?
    If so, you should be sending your logs back to Eric and he will take a look at them, make any adjustments he feels are needed.
    - William
