14.7 is stoic. So that's normal for being on the gas cruising, way to lean if on boost. Are you going WOT?
And its normal to go lean when letting off/shifting... no gas = all air = lean.
Posted from a fone.
This is a discussion on torqued performance maps for opensource within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I recently reflashed my ecu to stage 2 from torqued performance and the car seems to be running good all ...
I recently reflashed my ecu to stage 2 from torqued performance and the car seems to be running good all except for my afr gauge reading anywhaere from low 14s to 15. Also when i let off the throttle it seems to drop into the leane range. All i want to know is if this is normal or not, I emailed the guy i talked to when i first bought the map and he still hasnt got back to me. I figured id play it safe and ask on here to any information is appreciated.
Posted from a fone.
That's normal.. when you let off the throttle it should go all the way lean and max out the gauge because no fuel is entering the engine at that point.
