Results 1 to 9 of 9
This is a discussion on Looking at going Stage 2+ ....gauges?!? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I'm looking to start modding my 2011 WRX, and I'm planning on adding a new TMIC, EBCS, fuel pump, CAI, ...
    Aug 2012
    I'm looking to start modding my 2011 WRX, and I'm planning on adding a new TMIC, EBCS, fuel pump, CAI, in addition to the TBE. I'll be going the etune route since I don't have a tuner closer than 4 hours away. My question is, are gauges necessary, or is that more for people self tuning? If so, which ones are recommended (boost, wide band, oil pressure...)? The car is my daily driver and won't be tracked any time soon. Any advise is appreciated. Thanks in advance!
    Re: Looking at going Stage 2+ ....gauges?!?
    Boost is important on any modified car. WBO2 is needed for the email tune to dial in OL fueling. Beyond that, it's up to you. I'd do EGT then oil temp before oil pressure, personally.
    Aug 2012
    Thanks a lot! I was thinking of starting with a boost gauge and WBO2...maybe more down the road.
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    You are etuning. Definitely get a Wideband O2 (I like AEM). They are cheap and easy to wire.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Aug 2012
    Mar 2012
    Palm Beach, FL
    Quote Originally Posted by Helgadaddy View Post
    I personally wouldn't go that route. Just a standard UEGO. You should be able to find it cheaper than on RSD.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    Registered User Alexmartynyuk's Avatar
    Oct 2008
    Vancouver
    You can monitor most of parameters through RR Logger so gauges arent really necessary but are good to have when not logging or tuning. You will need a wideband o2 sensor, I would recommend the aem uego, you don't have to recalibrate it like the innovate. Don't get the 2 in 1 because i'm not sure if you can log it in RR logger.
    Aug 2012
    Alright, I think I'm going with the AEM analog Wideband and matching AEM analog boost gauge, housed in the SMY 2008+ cluster bezel pod. Really like the stock look of it all.
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Keep in mind that the AEM UEGO's controller is integrated into the gauge, so you will need to wire a serial port FROM the gauge.
    Facebook me here
