Have the car professionally tuned. A quality TMIC, 3-port EBCS (or better yet, hybrid boost control), and EWG would all help out.
This is a discussion on Tweak stage 2 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I am currently running an 06' WRX with a stage 2 ots map. Does anyone know how I can tweak ...
I am currently running an 06' WRX with a stage 2 ots map. Does anyone know how I can tweak it so the boost doesn't drop to 10psi around redline? I haven't messed around with AccessTUNER Race much, but I would like to learn. I have found out how to change some things, but I done really know what I'm doing. If anyone has any advice as to properly tune it, I would appreciate it.
I have an STi TMIC and a vf39 waiting to be put on, I tried today but I couldn't get my old turbo of. I was just thinking of something to do in the mean time.
You can always try the other STG 2 maps. I'm just learning the access tuner myself.
You need to learn about how turbochargers work and to read compressor maps. The map tapers the boost to 10 PSI at redline to stay within the efficiency range of the turbo. The TD04-13T is a small turbo for the 2.5L motor. If you increase the boost to, say, 12 PSI at redline, the compressor will spend more energy heating the intake charge than compressing it into useful air for the cylinders. As such, the car will make less power than with the 10 PSI tune. This is a common misconception among those who do not understand turbochargers: more boost does NOT mean more power! You need to tune the boost to remain within the optimal efficiency range of the turbo -- optimizing volumetric efficiency with the amount of air flowed by the turbo compressor. A turbo system is a closed loop feedback loop!
I'd recommend reading the Tuning 101 wiki on NASIOC. Until you have finished, I'd leave the tuning to the professionals.
Facebook me here
Originally Posted by Mikie13
I agree
Facebook me here
- William
make more power not only because of being able to run more timing but because there is slightly more air, trust me I know, i'm running my td04 @ 21psi and getting a more efficient intercooler helps, I wasn't even able to add much more timing after getting the tmic but in similar conditions the car put down a decent amount more power than it did with the stocker at the same boost curve and afr. Pushing a turbo into its less efficient area will make it flow a little more but less efficiently which means more flow more power as long as you are able to cool the air charge down.
This still has nothing to do with compressor efficiency! But yes you're right, running at 100% VE (as if you even could) would not necessarily provide you optimum power. BTW the reason you're able to run more boost with your new TMIC has more to do with the lower pressure drop of a bar and plate intercooler than the reduction in charge temp.
Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
Facebook me here
At higher boost pressures the IC can't cool the air that much anyways. They tested the difference between the hotside endtank to the cold side end tank on the Mexico STi here and it was only 10-15 degrees.. and that car has a massive FMIC with a 5" core. Running the turbo out of it's efficiency range is going to net less power, no matter how good your IC is.
Lol, why doesn't this have anything to do with compressor map efficiency, aren't we talking about running a turbo running in a different efficiency range after less pressure drop after upgrading the intercooler? I ran the same boost before I switched to a redicilously large tmic. Anyway to the op, if you got a vf just install that and don't try to tune the car yourself if you don't know what you are doing. A td04 will not flow much more than 10psi at redline even if you ramp up wgdc to try and get it to, it cant flow enough air to cause pressure higher than that at high rpm. Changing boost will require remapping other parameters like timing and afr.
