Tweak stage 2 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Tweak stage 2 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by MainFrame You can generally run a little more boost safely with a better intercooler, but that has ...
    Registered User Alexmartynyuk's Avatar
    Oct 2008
    Vancouver
    You can generally run a little more boost safely with a better intercooler, but that has no effect on the choke point of the compressor. If you're hitting the choke line on the compressor it doesn't matter how good your intercooler is.
    That exactly what I was trying to say, i'm not the greatest with explaining stuff with letters I hold about 21psi till about 5k and around 15.5 @ redline using a hybrid boost control method(grimmspeed 3 port ebcs and a hallman pro rx in parallel), so basically I run the 3 port under part throttle to prevent a ptfb situation and the mbc under wot runs.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Alexmartynyuk View Post
    Lol, why doesn't this have anything to do with compressor map efficiency, aren't we talking about running a turbo running in a different efficiency range after less pressure drop after upgrading the intercooler?
    Changing the IC isn't going to change the compressor map.. the reduction in pressure drop, if anything, should cause the engine to ingest more air, pushing the turbo further to the right of the map, and closer to the choke line.. although that's something I've never thought about before.
    Oct 2008
    Vancouver
    Yeah a compressor map will never change, I was only trying to say upgrading an intercooler can help when pushing the turbo to the right of the compressor map.
