Results 1 to 15 of 15
This is a discussion on afr question within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hello, just a quick question on afr. On normal shifting why does afr dip briefly rich ( 11.6) or so ...
    Jan 2011
    Mission Viejo, Ca
    afr question
    Hello, just a quick question on afr. On normal shifting why does afr dip briefly rich ( 11.6) or so between shifts? Thank you.
    It should go lean between shifts, since when your foot is off the gas, the injectors shut off.
    Aug 2012
    Bristol, CT
    Ever notice how if you're boosting though, in between shifts your rpm gauge raises even though your foot isn't on the gas?
    Oct 2005
    Late Devonian
    Quote Originally Posted by nsibanez View Post
    Yeah - a bit annoying at first but it ends up helping keep the revs up. I believe it is for emissions purposes.
    I'm honestly not sure if that results in a rich spot.
    A vent to atmosphere BPV will for sure though.
    Aug 2012
    Bristol, CT
    Same thing as a BOV?
    Jan 2011
    Mission Viejo, Ca
    That's kind of what I was thinking when the rpm jumping a tad at the shift. The afr dips only for a split second and then goes to where it should be. Just wondering why if anyone knows.
    Moderator Donkey's Avatar
    Da boonies
    It would probably help if you listed car/year and mods..........
    2002 FORESTER S
    1998 FORESTER S
    Jan 2011
    Mission Viejo, Ca
    11 wrx, cai, tbe, ebcs, TP stage 2 custom tune.
    Oct 2005
    Late Devonian
    Yup.
    Registered User Alexmartynyuk's Avatar
    Oct 2008
    Vancouver
    its called shift flare, its not because of emissions. I have noticed it is worst if you are running extremely rich and happens a lot more in the low to mid rpms.
    Aug 2012
    Bristol, CT
    Yup.
    Noticed a good 1-2 mpg average drop with it, so I took it off.
    Plus in 4th, letting off the gas at around 2500-3000 rpm range I always heard a high pitched squeek. Figured that could have been the problem, haven't noticed it since I took it off either....turbo flutter by chance?
    Oct 2005
    Late Devonian
    Yeah, if it wasn't blowing off enough it would surge the compressor for sure.
    Aug 2012
    Bristol, CT
    I don't think it's anything serious. I guess they're adjustable, but I don;t know how to do that...so I think I'm going to sell it soon. Nothing wring with it...bought it off a coworker with an 11, and only was used for about 2000 miles. Same with me. I just removed it to troubleshoot the noies, and just don't care about putting it back on.
    Oct 2005
    Late Devonian
    Yeah a recirculating one that is adjusted correctly is the only way to go if you aren't happy with stock. I never messed with mine but have heard the newer models are a bit weak if you are going much beyond stage II.
    What valve?
