Results 1 to 4 of 4
This is a discussion on When should I get a tune? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hey guys I'm new to this site so I hope I'm posting in the right area, if not I apologize! ...
    Oct 2012
    Vancouver BC, Area.
    Hey guys I'm new to this site so I hope I'm posting in the right area, if not I apologize! Anyway I own a basically stock 04' WRX and I'm looking to install a new up pipe, down pipe, and an intake. This car is my DD so I don't want to do to much to it's engine at the moment. ANYWAY, when should I get a tune or do I even need a tune after I install these 3 parts? Since I've only owned this car for a few weeks I'm still new and learning about new things about it. So yes my question is when should I get a tune or do I even need a tune after these installs?
    Thanks
    Rippel
    This is what I'd do, in order of preference:
    1. Nothing. This costs a lot of time and money, because "nothing" means maintaining the car with authentic Subaru parts according to the manual. "Nothing" is also a prerequisite for any/all changes you want to do.
    2. Up pipe. No tune needed, but you will have to fix the CEL with a resistor.
    3. Down pipe. Tune needed.
    I would not bother doing a down pipe alone, and I would not do the intake under any circumstances here.
    This means I'd not do a down pipe without the up pipe, and I'd not do the down pipe without a tune. The tune goes with the down pipe, if you ignore the intake. Since you should forget about the intake, down pipe --> tune.
    I would do an up pipe without a tune though.
    Aug 2012
    Re: When should I get a tune?
    Yes, you need a tune. And do a little more research on intakes, it won't add anything impressive. I jumped the gun on an intake and it's sitting in my basement at the moment.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
