Results 1 to 15 of 18
This is a discussion on Learning how to operate COBB AP within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I own a 2011 WRX STi, and got an accessport and stage 1 the other day. I've been using it ...
    Registered User Mike193's Avatar
    Nov 2011
    North Jersey
    I own a 2011 WRX STi, and got an accessport and stage 1 the other day. I've been using it as a boost gauge, but would also like to live monitor a few other things, what are some good things to monitor? Like maybe trans temp, or exhaust temp etc.
    Registered User jimbo058's Avatar
    Apr 2010
    Colorado Springs, Colorado
    Air/Fuel Ratio, Intake Temperature, and Wastegate Duty Cycle are other interesting features to monitor. A/F ratio is one of the most important items to keep under control to avoid catastrophic engine damage from occurring. I have also used the AP as a shift light at the drag races !!!
    zax
    zax is offline
    Tony Vargis zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by jimbo058 View Post
    Air/Fuel Ratio....A/F ratio is one of the most important items to keep under control
    Useless if you don't have a WideBand O2 sensor.
    Things you really want to monitor:
    DAM
    RPM
    Calculated Load
    FBKC
    FLKC
    Boost
    I'm not familiar with the newer CANbus ECU (2008+ WRX/STi), but with the older ECUs, the more parameters you log, the lower the resolution of your logs. Therefore, it's always best to reduce the number of parameters you log to the bare essentials.
    Facebook me here
    Re: Learning how to operate COBB AP
    Quote Originally Posted by zax
    DAM
    RPM
    Calculated Load
    FBKC
    FLKC
    Boost
    What you log is dependant on what information you're interested in. If you're interested in boost, the parameters will be different than if you're interested in CL fueling, etc.
    For all-purpose log, what Zach mentioned plus:
    Throttle position
    Boost error
    Ignition timing
    As for the resolution comment, the same is true. You have XX bandwidth; the more parameters trying to go through, the less resolution you have on each.
    Nov 2011
    North Jersey
    I want to make sure tune is running correctly and engine isnt being harmed. Please dont use any abbreviations, im bad enough at this as is. TY.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Mike193 View Post
    Without a Wideband O2 sensor, that's going to be tough. This is more reactive than proactive, but it works... logging FBKC and FLKC (especially FBKC) with calculated load, TPS, and boost will tell you if you are knocking at high-boost and load. That is the most common failure point from tuning.
    Facebook me here
    Nov 2011
    North Jersey
    Uhh, no offence, but WTF is FBKC, FLKC, TPS. Idont see those under the data logging section, and there are like a hundred things lol
    zax
    zax is offline
    Nov 2008
    WTF = What the ****
    FBKC = Feedback Knock Correction
    FLKC = Fine Learn Knock Correction
    TPS = Throttle Position Sensor
    Facebook me here
    Nov 2011
    North Jersey
    Thank you sir, although I was informed on WTF years ago hahaa, just new to the AP and so far, I'm getting very discouraged and considering just selling it.
    Registered User WRidesX's Avatar
    Oct 2011
    CO
    This has all been very helpful to hear considering I'm debating still between the two tuning options. I do like the idea of using the AP as a gauge and a way to monitor (mainly my A/F ratios.
    '02 WRX Bugeye; Midnight Blue / Black Pearl
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by WRidesX View Post
    Guys. If you don't have a Wideband O2 sensor (which the AP cannot read), there is no point in monitoring AFRs since the AFRs that are reported by the narrow-band O2 sensor are only useful when averaged over a long period of time and only when rich.
    Facebook me here
    Nov 2011
    North Jersey
    I'm pushing 18.5 at full boost. Alot of friends are claiming this is overboard, is that just because they don't know much about these cars? I'm only on a cobb stage 1 tune... I dont wanna ruin anything running too much boost
    zax
    zax is offline
    Nov 2008
    Sounds like your friends need to learn how to read. From the 2011 STi Cobb Stage 1 map notes:
    Stage1 93 v301 Boost Select - Intended for 2008-2011 Subaru Impreza WRX STi vehicles with stock intake
    system, and a stock exhaust running 93 or 94 octane petrol. Boost Targets: ~18psi (S#) or 15.5psi (S) peak boost
    pressure tapering down to ~13psi by the 7000 RPM redline, +/- 1.0psi.
    https://static.cobbtuning.com/cobbtu...20-%20v301.pdf
    Facebook me here
    Nov 2011
    North Jersey
    Looks like I need to learn how to read. thank you sir.
    Nov 2011
    North Jersey
    So tonight i played around with the AP and it really is neat and cool. 2 things i however couldn't figure out. 1. I couldn't find 2 step launch, and i couldn't find flat foot shifting.
    If anyone can give me some real quick pointers or tips it would really help a guy out.
