Don't launch your car and your tranny will be fine. You'll be fine on stage 2. If you need some parts let me know.
This is a discussion on Going Stage 1 Possibly Stage 2 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Hi to you all once again. I need your humble advice once more. I was at the track recently and ...
Hi to you all once again. I need your humble advice once more. I was at the track recently and was insanely discouraged because I was running a whole second slower last year (it's too embarrassing to say). So now I'm looking into going stage 1 (filter and access port) to hopefully lower my 1/4 mile time. I'm sure part of my problem is having an automatic and my car is an 02' so it has a "glassbox" tranny. I am wondering if going stage 1 will be worth it or if it will harm anything? Can the same access port I used for my car be used on other WRX, etc in the future? Is stage 2 out of the question?
Other things to mention: I have cat-back exhaust with 2.5 inch piping, I'm thinking of going with 3" before tuning and staging up. I also already have a panel aftermarket filter.
Any advice or help would be much appreciated. Thank you all.
'02 WRX Bugeye; Midnight Blue / Black Pearl
ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
[/SIZE]
USE COUPON CODE FIRST5%OFF to receive a discount of your first order
Kronos has Special Pricings on Process West & Agency Power!
CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
The automatic transmission will hurt you. However, it isn't as commonly broken as the 5MTs on some of the Bugeyes.
A 2.5" catback will not limit you on the stock turbo anything significant. I would spend that money elsewhere, or use it to enjoy your car with the new tune.
You do want to get rid of the uppipe cat, though.
is this you Daily Driver?
STAGE 1 IS MORE FUN BUT STAGE 2 THERE'S MORE TO DO
be easy launching it but hard accels are better than flooring it in neutral and dropping it in drive. or you can brake boost your launches. but skip stage 1 go for stage 2. replace the stock uppipe like EJ said because the stock cat will tear apart under higher levels of boost, but turboback exhaust, upipe and stage 2 AP tune and youll be good. the 2.5" catback will work but 3" will obviously get you better flow. not 100% sure if the aftermarket filter will work with your stage 2 AP tune, id just stick the stock one back in as its not very restrictive in the first place. and if your looking foor more of an airfilter sucking sound you can remove the intake silencer in your fender well and that will give you a sound mod that wont mess anything up
Thanks for that advice. I forgot to mention that the uppipe was already done, Perrin aftermarket. I have also removed the snorkle silencer POS from the fender too. I was just considering 3" because it would be the most I would expand the piping to anyway, that way I could no longer blame that for anything. Couldn't I go stage 1, then add a downpipe later and retune with the access port again?
lol at "glassbox." You can thank the DSM crowd of inexperienced drivers for that moniker.
If you don't believe me, PM Ray. He's pushing about 340wtq through the "glassbox" 2002 Transmission.
Facebook me here
Originally Posted by Mikie13
It's not cost-effective; likely the difference would be within the margin of error on the dyno. You'd be far better off spending the money you would pay for a new catback on a custom reflash. If you're already doing a custom reflash, spend it on a TMIC. There are a bunch of other modifications which will be more beneficial with the stock turbo than a 3" catback.Originally Posted by WRidesX
You can get a custom reflash with your AP; if the shop tunes OpenECU, you can go that route, too.Originally Posted by WRidesX
A new TMIC would replace your OE unit with a more efficient unit.
