Going Stage 1 Possibly Stage 2 - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
This is a discussion on Going Stage 1 Possibly Stage 2 within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Originally Posted by WRidesX Wow you all have given me a lot to consider. I really appreciate the criticism, seriously, ...
  1. #31
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    Quote Originally Posted by WRidesX View Post
    Wow you all have given me a lot to consider. I really appreciate the criticism, seriously, it helps. I will certainly consider a new TMIC (should I install this post or pre tune with Access Port?).
    I'm assuming the maps that come loaded on an Access Port would address and / or solve many of these issues that you all mentioned i.e. back pressure, running rich vs. lean, low end acceleration issues, etc.?
    It's nice to have someone who appritiates good advise, a lot of people consider criticism an insult. The truth is I'd rather hear something I didnt want to hear vs breaking parts and spending money.
    If you want a new TMIC I'd install it pre tune so that it can adjust itself into the tune with the rest of the new stuff. Otherwise it will have to go through a whole new learning process(driving easy/mild for 20+ miles). The Cobb AP's stage 2 is pretty safe and will work with a wide variety of Cobb parts(intake and full exhaust with a slightly bigger TMIC). You will notice a nice jump in power over stock with catback, the pull will be much smoother as well. It's also pretty easy to resell the APs on here and craigslist/eBay if you decide later you want to go further.
    Like I said if your worried about 1/4 miles it's gunna come down to how fast you get off the line, I couldn't even run a high 12 with my 16g 02 wrx 5mt without nearly destroying the car off the line and it felt fast to everyone who rode in it including me.. So don't let times get you down. If your happy with the way the car runs, who cares what it does at the track. Especially being a DD, don't remember if you said it was.
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
  3. #32
    Registered User WRidesX's Avatar
    Oct 2011
    CO
    Quote Originally Posted by cjm1991 View Post
    Yes it is my DD. So could I use the same Access Port I will use for Stage 1 with going Stage 2 when I decide to?
    I know getting off the line fast with an 4EAT will be tough to navigate in itself. I'm just hoping the AP will help open it up a little more.
    '02 WRX Bugeye; Midnight Blue / Black Pearl
  4. #33
    The same device, yes, but a different map. The first three things to do are to read the map notes, read the map notes, and read the map notes. The parts supported will be listed; stick with that list for shopping. Otherwise look for a custom map instead in my view.
  6. #34
    Oct 2011
    CO
    Ha that was great: and the first rule of Fight Club is..
    So since you recommend sticking to that list for shopping, will it matter that I already have a custom CBE, or will I have to redo it to make it within regulations of said shopping list?
  7. #35
    I don't know about recent cars but for cars before 08 in my view a cat back may as well not exist, it made no difference.
  8. #36
    Registered User Alexmartynyuk's Avatar
    Oct 2008
    Vancouver
    Same section of road? Same direction? Same atmospheric/weather conditions?
    A 2.5" catback will still be an improvement over OE (2.25").
    yes, same day actually. Maybe 2 hours apart as far as logs go.
  9. #37
    Oct 2011
    CO
    Thank you to you all for the advice. I'm probably going to be purchasing the AP next month. Anyone else who has any other pointers please keep posting. I am still in the research phase after all.
  10. #38
    Oct 2008
    Vancouver
    Have you thought about going opensource instead of the ap?
  11. #39
    Oct 2011
    CO
    Quote Originally Posted by Alexmartynyuk View Post
    Okay I need this explained. What is the difference? Which is better?
  12. #40
    Cobb AP vs OpenECU (Tactrix/Romraider/ECUFlash)
    Resident Tuner @ WTF Tuning
  13. #41
    Oct 2011
    CO
    Thanks for the link! That is helpful. Now I'm a little weary of using either method if my engine could fail due to it or turn my ECU into a paperweight. Then again, I only plan on going stage 1 for now.
  14. #42
    Oct 2011
    CO
    Now I need to know about this: I'm considering getting a downpipe like this. Any opinions?
    CNT Racing Catted Downpipe - DP-02WRX-CATTED - Subaru - Impreza - WRX - From: 2002 - To: 2007 | NextGenTuning.com
  15. #43
    Re: Going Stage 1 Possibly Stage 2
    Welds look like Michael J Fox did them, and may not fit great (I had issues with one on an '08). From a performance standpoint, should be similar to any other downpipe with a cat in the upper half.
  16. #44
    Oct 2011
    CO
    good advice. My main concern is if it will match up with my current setup: like the mouth connecting to the piping after the turbo and connecting to my CBE, which I believe is 2.5" but looks like 3" upon measurement.
  17. #45
    Oct 2008
    Vancouver
    Well it depends, if you get a custom opensource tune it will generally be cheaper than a cobb pro tune. both can be equally as good though if they are specific to your mods.
