WTF Tuning Part 1: Reading, Data Logging, and Analyzing Logs - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
This is a discussion on WTF Tuning Part 1: Reading, Data Logging, and Analyzing Logs within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; Subscribed!...
    Palmyra, NJ
    Subscribed!
    Moderator Donkey's Avatar
    Da boonies,Va
    I'd rather keep the specifics of that stuff out of this thread a bit.
    Np! Yeah,things could off course quick. I would maybe change the "manifold/boost pressure" parameter to "Manifold Relative Sea Level Pressure (2-byte)" since Romraider has about 6 different manifold reference parameters.
    2002 FORESTER S
    1998 FORESTER S
    May 2010
    Pittsburgh, PA
    I actually have to use the 'Boost Pressure' (4-byte) parameter. For some reason, the Manifold Relative parameter (4-byte) actually maxes out at 18.35 psi or something close. I have always had the luxury of basically unlimited parameters and resolution, however. I didn't see the 2-byte version of the boost pressure parameter.
    Do you know what ECU IDs you would recommend using that parameter for Vs. Boost pressure? I will add in to use the 2-byte when possible shortly.
    Also, on a similar note... anybody with a Cobb... Please tell me the Cobb version of the definitions =P
    2011 STi Build Log
  6. #19
    I ran into an issue similar to this maxing out ~18.5 back in the day. I need to go back to find logs of what parameter that was. I always just log MRP Corrected.
    The "How to Make Useful Data Logs" link I posted earlier talks about some of the Cobb parameter naming differences, if that's what you're referring to.
    Resident Tuner @ WTF Tuning
  7. #20
    Da boonies,Va
    The earlier 32 bit ECU's use it (04-07 STI/Legacy).
    2002 FORESTER S
    1998 FORESTER S
  8. #21
    May 2010
    Pittsburgh, PA
    Will look it over and update it. Thanks.
    Okay, will throw that detail in.
    Updated. I'm still not confident in the Cobb conversion names I found - feel like I am missing a few more. Will add them if people get hung up though.
    As per what definitions to use for what car.. I'm going to have to let people figure this out on their own a bit. I think there will be a good bit of trial/error with it regardless.
    2011 STi Build Log
  9. #22
    Registered User SingleSpeed's Avatar
    Aug 2012
    Fairfax Station, VA
    Good stuff, can't wait to see more.
    2012 WRX 5 Door - DGM
  10. #23
    Registered User Phobic's Avatar
    Aug 2012
    Boston, Ma
    will be reading through this a few times until I learn a bit more. Great resource!
  11. #24
    Registered User Axex's Avatar
    Aug 2011
    North Cackalaky
    nice thread man, thanks for taking the time to do this. I want to get into tuning and have started reading some of these books already. I definitely have the know-how, its just a matter of dedicating the time and tracking down all the different helpful threads. This will definitely be a good place to start!
  12. #25
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by Phobic View Post
    Quote Originally Posted by Axex View Post
    No problem. I'll do a few more posts as time goes on. I'd like to spend a bit more time on this one though incorporating any feedback. Just let me know if you think of anything that should be included with the material.
    Books are nice - those authors spent a lot of time learning. Might as well soak up what you can. Credible information that's presented in a logical manner.
    2011 STi Build Log
  13. #26
    Registered User free2be4ever7's Avatar
    Nov 2011
    chicago burbs
    im in on this one too!
  14. #27
    Oct 2005
    Late Devonian
    How about making one new thread, put the links to the different parts, and we'll stick it?
    Also, Ron, the bottom three stickies are of very questionable value anymore IMO. The Cobb AP maps one is pretty dead too.
  15. #28
    May 2010
    Pittsburgh, PA
    Re: WTF Tuning Part 1: Reading, Data Logging, and Analyzing Logs
    Myco,
    I will probably copy over some of the first post to a new thread for sticky use along with an index. I'd like to restructure this first one anyhow when I have more time.
    EDIT: Created the index page in the tuning forum.
    2011 STi Build Log
