TD05 tuning
Results 1 to 10 of 10
This is a discussion on TD05 tuning within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; i have a 2003 wrx i am about to to put a TD05 16G turbo on it and i wanted ...
    Jan 2012
    LA
    TD05 tuning
    i have a 2003 wrx i am about to to put a TD05 16G turbo on it and i wanted to know from someone who has done this how much % i should increase the Fuel!! ???
    There are several variations of that turbo available.
    Go to the tuning sub forum, post your specific parts, and post which mechanism you are using to flash the car -- open source, proprietary mapping, etc.
    Man is a brute.... If you're cruel to him, he respects and fears you. If you're kind to him, he plucks your eyes out. Alexis Zorbas
    I lied. I cheated. I bribed men to cover the crimes of other men. I am an accessory to murder. But the most damning thing of all... I think I can live with it. And if I had to do it all over again - I would. Benjamin Sisko
    Jan 2012
    LA
    TD05 16G
    i have a 03 wrx i am about to put a TD05 16G turbo on it for more speed and all that good stuff!!! i wanted to know how much % i should increase the fuel??? has any body done this to their car that can help me out?
  5. #4
    Registered User metaldahlberg's Avatar
    Sep 2010
    NH
    Are you tuning it yourself?
    Contributing unsolicited, worthless opinions since 9/10...
    The project I spend all my money on.... <---- Click it
  6. #5
    What fuel? Which 16G variant?
    Resident Tuner @ WTF Tuning
  7. #6
    Jan 2012
    LA
    Yes i have the equipment and everything just not a awd dino!! so i was wondering if someone had done this before so i can get the car mapped ball park until i get the money!!
  8. #7
    OMG WTF MainFrame's Avatar
    Texas, United States
    What AFR are you targeting? That will dictate how much fuel you need to add. If you're too lean in your logs, add fuel, too rich, pull it back a little.
  9. #8
    Moderator Donkey's Avatar
    Da boonies,Va
    You don't just increase it by a percentage. Take the car to a professional or buy a premade map for your mods. There is alot more things to change than just fueling. Your going to need larger than stock injectors for that turbo.
    2002 FORESTER S
    1998 FORESTER S
  10. #9
    Jan 2012
    LA
    im what ever it comes stock with a tdo4! i know im going to need about 10% more fuel but i dont know how much exactly! its like 17.3 -1 right?
  11. #10
    Like Donkey said, you can't just add a predetermined amount of fuel, and there's lots of things to change besides just fuel maps. If you're referring to 17.3 - 1 AFR you're way off. You're going to want to target somewhere around 14.5:1 at idle and cruising and around 11:1 at WOT. The load range is important, you can't just target one AFR for the entire map. The OEM td04 and a 16g are two entirely different turbos that flow radically different rates.
    To me it sounds like you need to take the car to an experienced professional and have it tuned.
