Stage 2+ 350/380HP?
Page 1 of 6 123456 LastLast
Results 1 to 15 of 86
This is a discussion on Stage 2+ 350/380HP? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I want more then the cobb stage 2 map. With a pro tune and these mods how much HP will ...
    Registered User SPT2011's Avatar
    Apr 2011
    NJ
    Stage 2+ 350/380HP?
    I want more then the cobb stage 2 map. With a pro tune and these mods how much HP will I gain? Any suggestions are appreciated or anything I missed for this setup please let me know. Thanks!
    -Spt exhaust
    -AEM intake
    -Cobb Downpipe
    -Process west TMIC
    -Walbro puel pump 255LPH
    -Grimmspeed EBCS 3 port
    -Deatschwerks top feed injectors 850cc or 1000cc or 1300cc? Which is best for my setup?
    Protune
    E85..........
    11WRX Ltd - COBB Stage 2+AEM HWG 93 Octane
    COBB Downpipe - SPT Exhaust - AEM Intake
    Pioneer AVIC-Z120BT - JL Audio W6v2 & XD600/1
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    that'll be a great step up
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Jan 2005
    Eh, whaaaaa?
    MAYBE 350AWHP with E85, but that depends on the dyno, the tuner, conditons, etc. I'd say 1000cc just to give you a bit of headroom.
    No real power number we give you will be accurate. Speak to your tuner about your goals and how to get there.
    Cody
            MainFrame's Avatar
    Austin, TX
    at least 1000s.. and suspension and brakes
    Not Asian Ying's Avatar
    Jul 2007
    Harrisburg-ish
    Probably get close to 350 whp. I like that set up. I'm looking at basically the same route after warranty is retired in 30,000 miles.
    2004 WRB WRX Cobb Stage II - Sold...2004 PSM STi Cobb Stage II - Sold...2011 WRB WRX Torqued Performance Stage I - Daily Driven
    My current average MPG
    May 2010
    Pittsburgh, PA
    I'd say if you are going with e85, get the big injectors. Takes about 33% more fuel last I checked when you use e85.... Some people even run dual fuel pumps when they get over ~350whp to make up for how much fuel you need. I'd go 1000s and e85.
    Check with your tuner on what EBCS they'd prefer. They vary in their tuning.
    Seems like a good set up though. I can't speak from experience concerning power mods - just forum whoring.
    2011 STi Build Log
    Apr 2011
    NJ
    I just talked to my tuner. He was saying that with 93 octane I can get close to 350whp without going the E85 route. E85 is a pain anyway with limited stations. It would work if I had a tune for both e85 and 93 so I can run 93 most of the time and flash the e85 only when I want.
    Any input at all is helpful I'm a newbie. I plan on doing all of this at once but I still have stock suspension and everything else stock. Do I really need a suspension or will the car handle fine stock with the added power.
    How easy is it to go back to bone stock in a few years when I want to sell the car?
    Apr 2011
    NJ
    injectors are confusing. From 850cc to 1000cc to 1300cc there all the same price?? If I'm not going E85 then is 850cc enough? What does bigger injectors benefit?
    Registered User Pylonpounder's Avatar
    Aug 2010
    Factoryville, PA
    Basically, the only benefit of really huge injectors is for if you're planning on upgrading the turbo. I'd still go with 1000's cuz they give you room to play with regardless and are the same price...atleast you'll have that bit done if the major mod bug bites again after this
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    If your not going E85 and staying with your stock bottom end then you will probably not even max out a set of 850s.. If you were going to build the bottom end and eventually go bigger I'd say go with 1000ccs but if this is your DD on stock turbo or even upgraded 400-420hp you should be fine with 850s
    Lead Wrench @ WTF Tuning, LLC
    Quote Originally Posted by SPT2011
    Easier resale when you go back to stock, since you'll have a broader spectrum of potential buyers.
    Resident Tuner @ WTF Tuning
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    i went with 1000cc's because i'm going to run e85, and i eventually plan on upgrading the turbo. With the 1000cc's I have the headroom to do all of that, and not worry about having to upgrade again.
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by SPT2011 View Post
    Something to keep in mind - I believe 1000cc injectors are harder to tune, and will normally result in a rougher idle. Don't skimp out on injectors, or you will be paying 2x over the cost difference of getting good ones in the tuning process I would bet. There are some people around here that would be able to offer their opinions on it. Generally, you want injectors that suit your needs. Definitely not too small, but not much larger than needed.
    2011 STi Build Log
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    We're on the same path. :-) ...well, almost. My PW TMIC shipped today. I am scheduled for my pro-tune on 10/12 at Agile. I am not replacing the injectors or pump yet; tuner said it's not needed on stock turbo. I'll be doing that later when I upgrade to the 18G.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
    Quote Originally Posted by Heide264
    A good tuner should have no issues getting a quality 1000cc injector to idle properly. Both the DWs/IDs should be no problem.
