07 wrx stage 2 help please
Results 1 to 8 of 8
This is a discussion on 07 wrx stage 2 help please within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; I have an 07 wrx with a catless tbe with a Cobb intake. I went stage 2 with the bulwinkle ...
    Registered User CSwrx22's Avatar
    Mar 2010
    Central NJ
    I have an 07 wrx with a catless tbe with a Cobb intake. I went stage 2 with the bulwinkle map and I am peaking at around 20 psi and over boosted once in fifth gear. But that was from a pull in fifth when I should have been in fourth so I disregarded that. I did switch in the restrictor pill that Cobb suggests if you overboost and only peaked at 15 which seems low to me. My main concern is peaking at 20 psi is that ok on stage 2? I did a learning view that seemed very good ill post that later.
    Mar 2010
    Central NJ
    bump anyone?
    Jul 2010
    Cincinnati
    I'm assuming you're using an accessport OTS tune? What do the map notes say? 20psi sounds high and 15psi sounds low, I'm thinking you should be in the 18ish range. I'm not 100% but doesn't COBB suggest not using a catless, I can't remember. Post a 3rd gear pull log to redline and we can see if everything is OK otherwise.
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Mar 2010
    Central NJ
    ok ill have to log this weekend and hopefully you guys can tell me whats going on and guide me in the right direction. Its an opensource map yes they advise not to use a catless unless tuned properly or having the different restrictor pill which i did and i lost quite a bit of boost with.
    Moderator Donkey's Avatar
    Da boonies,Va
    You will always overboost in higher gears. The only way to fix it is a tune specifically for your car or retweak his map to work with your car. Also overboosting and boost spiking are two different things.
    2002 FORESTER S
    1998 FORESTER S
    Mar 2010
    Central NJ
    I'm not sure what I'm getting then. I'll log as soon as I can then post it up
    Mar 2010
    Central NJ
    romraiderlog_20110806_110720.csv
    romraiderlog_20110806_110355.csv
    romraiderlog_20110806_111127.csv
    these are the logs you asked for let me know what you think. thanks
    Da boonies,Va
    Quote Originally Posted by CSwrx22 View Post
    Nothing more than a brief boost spike..........
    2002 FORESTER S
    1998 FORESTER S
