Rev Limiter?
Results 1 to 4 of 4
This is a discussion on Rev Limiter? within the Tuning: Electronic Engine Management forums, part of the Tech & Modifying & General Repairs category; So ive heard talk about rev limiters but never in a subi. Im assuming u set them to the desired ...
    Registered User BRADO934's Avatar
    Jul 2010
    Burlington, Ontario
    Rev Limiter?
    Im assuming u set them to the desired rpm and it stops you from going above..
    aka 7k rpm so that your dont pass the redline and blow ur engine?
    where could i find one and how hard is install
    You already own one. It will only prevent on-throttle over-revving and cannot help you if you over-rev off throttle; only a credit card can help you then.
    The world breaks everyone and afterward many are strong in the broken places. Ernest Hemingway
    I lied. I cheated. I bribed men to cover the crimes of other men. I am an accessory to murder. But the most damning thing of all... I think I can live with it. And if I had to do it all over again - I would. Benjamin Sisko
    Moderator Donkey's Avatar
    Da boonies
    Every single OBDII car has one from the factory along with a top speed limiter...............
    2002 FORESTER S
    1998 FORESTER S
  5. #4
    Feb 2010
    SL,UT
    Are you mistaking a rev limiter with launch control?
    Hawk-Eye Alliance #801
