ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Tuning: Electronic Engine Management
Tuning: Electronic Engine Management Engine management electronics are the topic of discussion, be it an ECU re-programming, a replacement standalone solution, or a piggyback computer. Eg. Autronic, S-AFC, TEC-3, Unichip, UTec, etc.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 10-26-2008, 06:25 PM   #1 (permalink)
2:43AM's Avatar
Angry Problem: AP v1 Dongle, USB-Serial Adapter and ECU Explorer
I am experiencing difficulty in communication between my laptop, which is using a Radio Shack USB-to-serial adapter, and an AP v1 OBDII dongle. ECU Explorer shows "disconnected". I tried restarting ECU Explorer after OBDII dongle is plugged into port and ignition is on. Nothing.
The Cobb drivers are installed in the same folder as the ECU Explorer software. I tried updating the drivers for the USB-to-serial adapter to the Cobb dongle drivers. Windows XP does not allow the update, stating that drivers contain no recognizable information (or something like that).
So I'm rather confused right now due to the lack of support out there for weird products! I'm ready to just use my DC-AC converter, plug in my DESKTOP computer in the car and drive around logging with that!
Can anyone help me with my USB-to-serial adapter issue and connectivity problems? Thanks!
__________________
05 WRX Prem. WRB
PDX Custom Map 18psi, SPT CBE, Helix Catted DP, TurboXS UP, Prodrive Springs, Cusco Rear Sway, 15% Tints, 5% Strip & Sunroof, Grillcraft Lower, Clarion MP3, Omori Boost, LC-1/DB WB, STi Splitters, V-limited Replica (or is it?), Enkei RPF1 17x8's, Yoko S.Drives 225/45/17's,
Installs Coming Soon: Dual Gauge Pod, SW GUS...
2:43AM is offline   Reply With Quote
Old 10-26-2008, 06:28 PM   #2 (permalink)
DUB
DUB's Avatar
I assume you've read through this right? AccessPORT cable supported in ecuExplorer!! - COBB Forums
__________________
"Blondes not bombs....brunettes not fighter jets"
Stg 2 Wagon
Bugeye Mafia #152
DUB is offline   Reply With Quote
Old 10-26-2008, 07:50 PM   #3 (permalink)
2:43AM's Avatar
Quote:
Yes, I have read all 20 pages, and it's a joke! But perhaps the joke's on me since all posts seem to point success with a v2 dongle.
I'm sort of digging the suggestion for ROMraider and the $15.88 OBDII dongle, straight to USB.
I am going to try to reinstall the dongle drivers (useless) tonight. The WinXP auto-installed USB-to-serial drivers may be the problem. We'll see.
__________________
05 WRX Prem. WRB
Old 10-28-2008, 03:52 PM   #4 (permalink)
2:43AM's Avatar
SUCCESS!!! I finally managed to get my laptop, USB-to-Serial AP v1 dongle to connect to my ECU using ecuEplorer.
First, I uninstalled the dongle drivers and the old copy of ecuExplorer. Then I did the following:
Install ecuExplorer 3.0.25 (installer version - the zipped version on Cobb forums did not work for me). Remember the install directory. Then install the AP dongle drivers into the same directory. With the ignition OFF, plug in the OBDII port (car) then plug the serial cable end into the USB-Serial port. Next, plug the USB plug into the computer. (NOTE: This time, the USB/Serial adapter did not ask for or display driver loading, etc. I just gave it a few moments to do its thing, then... Boot up ecuExplorer. EcuExplorer should automatically connect to the ECU.
To make life easier than to juggle a million links, I've hosted the files on my webspace. Get the correct files in a zip HERE
I'm glad it works now. EcuExplorer 3.0.25 is AP v1 dongle compatible. Very nice. I hope this helps others too because everything about ecuExplorer and the AP is frustrating, IMO. Now go log it up!
__________________
05 WRX Prem. WRB
Old 10-28-2008, 06:52 PM   #5 (permalink)
DUB
DUB's Avatar
nice
__________________
Stg 2 Wagon
Bugeye Mafia #152
Old 10-29-2008, 09:17 PM   #6 (permalink)
2:43AM's Avatar
I would also like to add that I now support ROMraider. What a bad ass program. ecuEplorer is garbage compared to ROMraider. Graphing abilities, better accuracy and display options make ROMraider my choice for logging and data acquisition software...on a FREE scale.
And best of all...it worked after the first install and is 100% compatible with the AP v1 dongle!
__________________
05 WRX Prem. WRB
Old 10-30-2008, 07:36 AM   #7 (permalink)
Quote:
Agreed.....
__________________
2003 Aspen White WRX Sedan Sold 10/08
TD05H-20G w/ 38mm EWG, Meth Injection & Hyperflow TMIC, selftuned w/ ROMRaider Dyno Chart METH vs 93 oct
2005 LGT Purchased 11/08
Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, selftuned w/ROMRaider, VF52
testes1010 is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
